Zig unit draining Battery Help please (1 Viewer)
GaryH61
81
172
Horwich Greater Manchester AKA Lancs
Elddis Auto Stratus
Since 2014
I don't have a leisure battery, yet, and the van (engine battery) is relatively new. However, on the ZIG distribution panel there is a 12v isolation switch as well as a pump and fridge switch. With the pump and fridge switches off and the Propex heater 'stat off, if I leave the 12v isolation switch on it will flatten the Van battery.
How can this be if lights off fridge off, pump not running and propex stat off. what other 'residual current can be being drawn from battery ?
Feb 24, 2013
13,054
101,383
Bolsover, Derbyshire
Hymer S800
not long enough
Logic would say it cant be drawing anything, like you already think
Has it worked like this before, ie without a separate habitation battery?
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
over how long is it going flat many modern vans drain the battery in a couple of weeks due to alarms and radios that draw current all the time
Lenny HB
53,309
149,501
On the coast in West Sussex
Hymer B678 DL
Also with only one battery the fridge & heater's electronics will be additional drain.
Not practical to run a modern vehicle without a separate leisure battery.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Zig units have long been accepted for throwing up faults of various types, and are pretty much un-repairable, (to my personal knowledge and cost). :(
scotjimland
2,250
9,767
A Woosh bang
A Zig unit is basically a charger and a 12v power supply unit .. like any other power unit, leave it powered up and it will be drawing a small current.. no matter how small.. it will eventually drain the battery..
You could test this by measuring the mA being drawn when nothing is being used.. the solution is to isolate when not required..
karl c
231
247
Lincolnshire
since 2010
if you have an amp meter put it in line on the live or + that will show if there is some thing pulling it down.
if there your showing a draw you can pull any fuse one by one till you find what is pulling your battery down.
the meter on the panel could be pulling a small amps over time.
Lenny HB
53,309
149,501
Hymer B678 DL
Zig used to make just 12v distribution panels as well as chargers I was assuming that what it is in this case as no 2nd battery.
scotjimland
2,250
9,767
A Woosh bang
yes , that may be the case .. not enough info from the OP
GaryH61
GaryH61
81
172
Elddis Auto Stratus
Since 2014
were 20 year old (Van years) circa 1995 not that modern
GaryH61
GaryH61
81
172
Elddis Auto Stratus
Since 2014
Will give it a go and see what draining = thanks:smiley:
43,301
49,286
Only takes a couple of days
I would expect a couple of weeks at least.
radio memory and alarm will put a load on the battery....radio memory may be 50ma
depending on make and the alarm (if fitted) may be another 50ma...just guessing.
100mah is 1amp every 10 hrs so in a 24hr day thats just under 2.5 amps.
80ah starter battery discharged to 50% = 16 days.....and at 50% discharged i doubt it would start the engine anyway.
Sounds very much like your engine battery is on its last legs if it only lasts two days
