You Must Be Fed Up Of Me
Discussion in 'Bessacarr' started by Doddy999, Jun 23, 2010.
  1. Doddy999
    Doddy999 Read Only Funster
    May 3, 2010
    160
    13
    Exeter Devon
    Have just aquired 2x 100Ah sealed batteries, OK given them through work.
    They are a year old but only used as backups so like new.
    My leisure battery is under the drivers seat so no chance of putting them there.
    Has anyone put 2 in there Bessacarr? if so where did you put them? Please :Smile:
    Doddy
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,266
    17,931
    YO11 2BD
    if your dinette is directly behind either front seat then thats the perfect place for extra batteries..
    i have two 110ah behind the driverseat under the dinette.
    whereever you find for them make sure the breather tubes are open to air.....through the floor:thumb: as the gas produced is highly explosive/flammable
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    It is possible to have a frame made and welded to the chassis and mount the battery/s outside the accommodation, Its a project I have done myself so I know what is involved.
    It is not something that that can be done without a lot of thought and design so I don't recommend it someone that does not have a engineering background or is prepared to pay some one to do it for them.
    On the other hand once it is done you free up space in the van and you have space for the extra batteries should you want it and I pleased with the results.
    Doug...
  4. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    These are sealed units John, so no breather pipe, the RRP are £330 each
    so was not going to take them to the Haz Waste Unit:Smile: and they weigh 35 kg each.
    Thanks Again Doddy
    Hi Doug we have a welder in work who loves foriegners on a Sat or Sunday so may
    get him to look, trouble is he hates going outside from his welding bay :BigGrin:
    Thanks Again Doddy
  5. pappajohn
    Aug 26, 2007
    30,266
    17,931
    YO11 2BD
    excellent idea of Dougs but dont let your man drill or weld to the chassis if its an Alko jobby...it will rot once the galv is destroyed.
    there are plenty of existing holes to bolt to. :thumb:
  6. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    ALL lead acid batteries can gas, are you sure about this ! Even if they don't have a tube vent they will still have provision for gassing which might mean a vented compartment.
  7. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    OK, well you will find that the top of the battery/s will be very close to the bottom of the floor base so you have to design the frame so that you can easily drop it to the floor or slide the batteries out, of course if you have sealed batteries the need to do this wont be too often.
    Also if it is a alko chassis you may not get the ground clearance, lots of planning and measuring.
    Good luck, Doug...
  8. Doddy999
    May 3, 2010
    160
    13
    Exeter Devon
    John, Brian & Doug really appreciate your help on this, as it
    is a fully sealed unit may look at Dougs idea, and yes it is an Alko Brian.
    Regards Doddy :thumb:
  9. Pugboxter
    Pugboxter
    Oct 13, 2008
    59
    I replicated and improved the original battery tray and fixings and fitted another battery on my 52 based Boxer, I had to relieve a small amount from inside the seat frames to squeeze the new 115 amh batteries in.
Similar Threads
  1. Dave K
    29
    2,177
