you got one?
Discussion in 'American RV's' started by lugnutt, Jan 3, 2008.
  1. lugnutt
    lugnutt Funster Life Member
    Sep 9, 2007
    1,185
    456
    wednesbury.westmidlands
    THE DEVICE ON THE RIGHT IS A GEAR SPLITTER
    THE INFO BELOW IS ALL ABOUT IT
    www.gearvendors.com
    MOTORHOME 3-Speed Automatic With Parking Brake
    3-SPEED AUTOMATICS gain excellent performance through gear-splitting and economy with overdrive. Motorhomes so greatly need the overdrive just to cruise at today's speeds that the product will pay for itself rapidly. The engine and all the engine driven accessories get to slow down 22% when in overdrive. Not only does this mean less wear but also these components (a/c compressor, alternator, transmission, etc.) will rob less power at the reduced rpm so the power is more efficient. Mileage improvements in the 20-24% percent range are proven in all back to back mileage comparisons done by major magazines and our 27 years of customers. There is no better component to improve mileage and wear and tear on your RV.
    The GEAR VENDORS is the finest product for Motorhome performance and is the only performance product ever used as standard equipment by RV, Truck and Car manufacturers. From Fleetwood Limited to GM's Callaway Corvette, manufacturers have used GEAR VENDORS because of its performance and engineering reputation as the best in the industry. Today we are found in 850hp Trucks in Off Road racing which you can watch on Speed TV most Friday's - this product is that durable.
    Motorhomes auxiliary transmissions Gear-Splitting is that ability to give you a gear between each of your forward gears sequentially when you want power. Study the Final Drive Ratios chart for your transmission (in the 2-wheel drive section) and notice how you will now have 4 underdrive gears, one direct drive gear, and one overdrive gear, for a total of 6 forward ratios. The close ratios keep the engine in the power from one gear to the next.
    You do not have to be Mario Andretti (or Michael) to enjoy this feature. When you are climbing a hill and 3rd (high) is too tall, commonly 2nd has the engine just screaming because it is too low. With the Gear Vendors installed you will have a 2nd-over gear that will turn on automatically at a 28% faster road speed than 2nd or you can select this gear manually whenever you want. Look at the Final Drive Ratios for your transmissions (GM model 475), (Ford model C6), (Dodge model 727) and you will notice that with a 4.56 rear gear (common in the 30-35 foot class A) that 2nd over is just like having a 5.16-5.27 (depending on brand) rear gear.
    This is what the trademark UNDER/OVERDRIVE™ refers to because the GEAR VENDORS will give you more performance than any underdrive or overdrive on the market. In fact you could purchase both an underdrive and an overdrive by any other manufacturer and still not have the performance of a GEAR VENDORS. The only thing an underdrive could do is get you a gear below first, which GEAR VENDORS cannot but you gladly trade that for all the performance, increased miles per gallon, and engineering of a GEAR VENDORS.
    RV's auxiliary transmissions All other underdrive or overdrive on the market are simply dual ranges. This mean they are intended to just give you three lower gears or three taller gears but you still have the same space between each gear you have now. This is because all competing units are small manual transmissions whereas the GEAR VENDORS is a fully hydraulic, planetary gearset designed like your automatic transmission.
    Now you will always have the right gear for power and economy. Plus, the GEAR VENDORS gives you many automatic features with out AUTODRIVE control system, which is standard and turns the overdrive on and off automatically just like your vehicle came factory equipped with the system.
    The addition of the Gear Vendors is going to change your vehicle performance, mileage, and enjoyment tremendously. You will not believe how much quieter it is to ride in (try going 44mph - that is the rpm that will take you 71mph in overdrive). Or looked at from an engine driven component standpoint - The same engine revs that currently take you 550 miles are going to take you 710 miles.
    Read also the section concerning your transmission in the 2-wheel drive section, then call us and we will arrange an installation at your local dealer or answer any questions you have. There is simply no good reason not to own a GEAR VENDORS in these vehicles.
    Note: Most Cass A's and Cass C's longer than 30ft have a driveline parking brake. To confirm, look at the rear of your transmission and you should see drum for the brake shoes (this steel or cast iron drum will be about 12 inch in diameter on GM and Ford products and about 8 inches on the Chrysler/Dodge). If your vehicles does not have the transmission mounted park brake then your product part numbers, description and prices will be listed in the Trucks/Towing section.
    MOTORHOME 3-Speed Automatic W/Parking Brake
    Application Guide GM / FORD / DODGE
    Part No. Make Application Description Comments Price
    Code
    3D0475 GM TH 400/475 3-Speed Auto Trans. With Driveline Park Brake Replaces tail housing. Park brake moved to back of 2-Speed. GM P30 Chassis up to 14,500 GCVW with Manual cable park brake. D
    3D0476 GM TH 400/475 3-Speed Auto Trans. with Driveline Park Brake Replaces tail housing. Park brake moved to back of 2-Speed. GM P30 Chassis up to 16,000 GCVW with Automatic hydraulic park brake. D
    3D0061 Ford C6 3-Speed Automatic Trans. with Driveline Park Brake Replaces tail housing. Park brake moved to back of 2-Speed. Motorhome John Deere/Oshkosh chassis. E
    3D0064 Ford C6 3-Speed Automatic Transmission with Driveline Park Brake. Replaces 7" tail housing. Replace output shaft with GV shaft (incl.). Park brake moved to back of 2-speed. '88-newer Foretravel and Beachcraft motorhome with Ford rear engine. Factory installs at GEAR VENDORS ONLY. G
    3D0730 Dodge TF 727 3-Speed Automatic Transmission. Kit comes complete with much stronger Bendix e-brake like Allison and Ford. Replaces 12" tail housing. New Bendix brake replaces stk. brake and is moved to the back of the 2-speed. '70-newer Dodge class A motorhome with driveline park brake. E
    Click Here for Price Schedule
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Now this does look interesting. Just might have to look into this one.Always thought overdrive is needed for comfortable cruising speeds.:Cool:
    I got bags of power but the wrong ratios.
  3. lugnutt
    Sep 9, 2007
    1,185
    456
    missing pic...sorry37.jpg (125.2 KB)
      File size:
      125.2 KB
      50
  4. olley
    olley Funster
    Jul 29, 2007
    3,862
    2,454
    Ipswich
    Hi minimum $3000 :Eeek: thats alot of fuel.
    Olley
  5. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Dave
    You should already have overdrive fitted to your bus haven't you ?
  6. lugnutt
    Sep 9, 2007
    1,185
    456
    hi yes i have overdrive,i was just wondering if anyone has this gear splitter as i never heard of it untill last night...or is it only in America same as the banks system
    dave
  7. Tony Santara
    Jul 26, 2007
    1,494
    114
    No mate the've been around in the uk for donkey's years usualy on commercial trucks
  8. lugnutt
    Sep 9, 2007
    1,185
    456
    ok tony i stand corrected,but it don't seem like anyone has it on rv's here maybe just older one's i usa i discovered it on a rv on ebay Item number: 230208817961
