Yokohama Tyres
Discussion in 'Tech/Mech General' started by jonandshell, Jun 25, 2013.
  1. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,333
    8,057
    Norfolk
    I know Yokohama have good name in performance car circles but has anyone got any fitted to their motorhome?
    It would be interesting to know how they compare to their European counterparts.
    We are desperately in need of new tyres and their 'all season' commercial tyre is very good value at some outlets at the present time.
    Any experiences with this brand in a commercial tyre context would be very welcomed!
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Soft compound, hence their popularity in performace car circles. Grip well in the dry wear very quickly indeed!
    Hve a look at some Maxxis, Kumho or more budget line Roadstone - they all last nd perform well
  3. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    However, I did hear that soft compounds don't get sidewall cracking so easily, so can last longer than a hard compound on a motorhome that does very few miles compared to a commercial vehicle and is unlikely ever to use up its tread.
  4. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    970
    1,698
    scunthorpe
    Vangos
    I went for Continental Vango 225 x 75 x 16 £132 fitted ( each ) , very quiet ( i had to turn the pre set on the radio and the sat nav volume down ), good feel to the road dosent wander on over banding etc .
    They enjoyed the Moroccan Trip :Rofl1:
    The MH was on Michelin campers , the Vangos are far better.:thumb:
    out of interest the original tyres were 215s but were £30 each more expensive :Eeek:
    so i went for the 225s ,
    Regards Graham
    • Like it Like it x 2
  5. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    I have had Yokohama tyres on both past and present Subarus and they are excellent. However for a motorhome, I'm not so sure. According to a Promobil test that I was reading online yesterday, they voted Continental Vanco Four Season the best of the bunch. I think this is the link (which you can translate using Google).
    http://www.promobil.de/test/drei-wetter-haft-93080.html
    Contis are probably a bit more expensive but this seems a fair price:
    http://www.tyre-universe.co.uk/continental-vanco-four-season-225-70-r15-112r-c-m-s-normal-tyre.html
    p.s. I've had Conti Vanco 2 on the motorhome for five years and they are good (not the all-season version though - might try them next time).
  6. rainbow chasers
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    You would think so, I would agree - but reality is different. A motorhome is effectively a fullen laden large van when you take weight into consideration. When carrying weight, you need a stiffer compound tyre to cope. The 'bounce' to get with heavy vehicles is handled alot better with stiffer sidewalls, as is the cornering as it resists the weight put on it. A softer compound would flatten easier, and be more like driving a jelly around.
    I always go a few brands up from budget and replace every three years. This will put you into the medium/hard compound bracket that will give good value for money without loss of grip or performance.
    Other tip I woild advise, is to see if there is a similar van in your neighbourhood. They would happily have your old tyres for £100 a set, and more often just means changing the steel wheels. This means you get £100 a set, and your neighbour saves money too!
    • Like it Like it x 1
  7. autoswan
    autoswan Funster
    Apr 3, 2012
    666
    1,706
    Swansea
    Hi ive just had Hankooks fitted. 215/70 R15C Michellins were on originally with loads of tread and good side walls but due to being 9 year old i changed them. The new Hankooks match up very well to the michellin spec when going through the data sheet with the fitter and at £87.50 per tyre compared to £140 each for the michellins it seems a very good choice. And they felt better on cornering coming back to.
  8. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    How many miles is that?
    I ask because I cannot imagine having tyres anywhere near 9 years without the tread wearing out!
    My van is a little over 2 years old and the fronts are starting to look worn with between 3 and 4 mm left. Its done 21000 miles. They will certainly need replacing within the next few months.
  9. Jim
    Jim Ringleader
    Jul 19, 2007
    26,988
    79,459
    Sutton on Sea
    I changed the original tyres on my 1999 Motorhome just two years ago. They were Michelin XC Campers and they had loads of thread left after 56k miles.
    But the compound had hardened, the rubber was like stone, on wet grass they would just spin. I fitted Avons at around £90 each and they have been superb.
  10. autoswan
    autoswan Funster
    Apr 3, 2012
    666
    1,706
    Swansea
    Hi. When I got the mh last year it had done just over 18000 miles its just under 22000 now . As jim said the rubber does seem hard on them but still loads of tread left its only because of thier age that I changed them. I was hoping old tyres would fit my works truck but they are R16 not 15 :cry:
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,333
    8,057
    Norfolk
    Our tyres were made in 2008, according to the DOT code. They are 185/75r16 Pirellis fitted as OE by Ford.
    They are splitting and perishing badly having only done 12K. The van was registered 3 years ago.:cry:
    We are looking specifically for m+s due to our winter skiing activities! We would like to be able to visit Germany during the ski season and m+s tyres are mandatory.
    The transit chassis is quite gentle on tyres. Rear pressures are only 48 psi, for instance. The vast majority of our annual mileage is during winter and the better traction off wet Summer rally fields will be handy too!:thumb:
    We both work and mileage is low, so I feel even soft compound tyres will perish before they wear out!
    After lots of searching, I have decided on Yokohama Y354. Prices where as high as £135 a tyre, but Black Circles .com came in at £88 a tyre fitted!:thumb:
    My best quote for Michelin or Conti was £760 a set!:cry:
    Anyway, the advice has been welcomed and I will let you know how they perform in due course!:BigGrin:
  12. cmcardle75
    Jun 8, 2012
    670
    263
    Reading
    Not everyone can afford a set of tyres every three years!
    Choosing a tyre that will reliably last ten years rather than five is the order of the game for some people.
  13. cmcardle75
    Jun 8, 2012
    670
    263
    Reading
    Indeed. Your mileage is much higher than average for a motorhome, so you'd be well advised to go for a compound that optimises tread wear. The suggestion for softer tyres is for a typical motorhome that only does a few thousand a year.
  14. coldstreamer
    coldstreamer Funster
    Feb 1, 2011
    209
    146
    Redcar
    Hi,
    Used Mich's for 20 years on various Vans, always very good, but 'Hard Ride' changed to Hankooks last year, brilliant, just like driving a good car rather than 4 ton truck. Makes distance driving more relaxed with great road holding... Really a huge improvment, wish they had been around years ago. Best Regards Mac
  15. rainbow chasers
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Shop around - I average £75 per tyre, which will get you some reasonable tyres. Budgets can be found from £55 for something like a roadstone.
    I always keep tyres in top notch, one because it will always be the rear that goes - witch can be a pain to change roadside, and secondly, it will be the rear that wipes out your fibreglass.
  16. chippy63
    chippy63 Funster
    Aug 19, 2007
    314
    152
    Birmingham
    After looking at this post, thought i would have a look at the tyres on our van, wish i had'nt
    they look original tyres, lots of cracks on the treads, and on two of them the sidewalls quite bad:Sad::Sad:
    So which model number for the avons and yokos, the mich & vanco are too much for me as i need four.
    Also how do i find the date on the tyres/
    Karl
  17. alfandM
    alfandM Funster
    Mar 12, 2012
    1,055
    1,077
    sweden
    we too opted for Hankooks, and are very happy with the purchase: thumb:
  18. chaser
    chaser Funster
    Feb 16, 2013
    8,126
    9,281
    uttoxeter
    Can't believe this thread has gone on for so long without someone saying you have got to have nothing less than new camper tyres every 5 years and at 79 psi weather you use them or not :Eeek:
  19. chippy63
    chippy63 Funster
    Aug 19, 2007
    314
    152
    Birmingham
    which hanhooks?
    Just checked dates on our tyres 0704:Eek!:
  20. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,643
    3,477
    Telford, Shropshire
    The point I do find worrying on this thread, and from day to day checking of tyres on motorhomes (and the owners reactions to my comments:Doh:) is how so many people check their tyres so rarely. When I learned to drive, which is a pretty long time ago I know but there are many motorhomers who have been driving for many more years than myself, it was drilled into me by my driving instrcutor and my father that tyres should be checked for pressure, tread depth and overall condition at least on a weekly basis. Perhaps I now have a touch of OCD about tyres and their condition but I know all of the tyres on all of the vehicles we own are in good condition, are within date and are at the apropriate pressures for the vehicle they are fitted to, that is four roadgoing vehicles and one trailer.
    Here's a little heads up for anyone unsure, if there is the slightest sign of sidewall cracking or cracking in between the treads the tyre is on its last legs, trust me people it will not heal up and get better! Check your tyre pressures weekly or at the very least just before you use your motorhome. We recently had a tag axle 5 tonne motorhome in with all but one tyre running at around 80 psi, the odd one out was at 27psi and on the front of the two rear axles. A blowout waiting to happen and the owner was surprised as he'd checked them not six months ago!
    D.
