Yet another Gennie Thread (1 Viewer)
markymark
241
25
New Forest Southampton
Swift 6 berth Coach built
Hi Si,
I was looking at getting a Kipor IG2600 but feel a little uneasy due to bad dealer after care and the reliability of the machine. I have saved the money up but dont want to get stiffed.
What would you reccomend at present
43,329
49,441
Hi Si,
A Solar panel.....:ROFLMAO:
havent used my 2600 genny since fitting my panel.
Planetgen
75
Taunton
RV
In fairness to solar panels they are good when the weather is there! To be honest I would look at a Planet. It is a brand made for us that we are building up. They come with a 2 year warranty too which is handy!
You would get a special price too as a fellow motorhome funster!
Give me a call for more info, I am in the office all night - again!
Si
43,329
49,441
got a spec on 'em Si,
2.6kva.....
DB rating,
Run time per ltr @ no load and full load,
weight,
modified or pure sine wave,
and socket type
Planetgen
75
Taunton
RV
Ok, I will list specs, not sure if this is ok to do? Havent spoken to Jim about sponsering yet?
Technical Specifications
Sound Level (DB) : 59 (7m)
Output Rated (kva) : 2.8
Output Max (kva) : 3.2
Output Voltage (V) : 230
Fuel Tank Capacity (L) : 7.5
Continuous Operating Hours Without Refuelling at Rated Load : 8.5
Dimensions (mm) : L560, W300, H500
Starting system : Recoil starter
Engine type : 171cc Single cylinder, 4-stroke, OHC, gasoline engine
Rated rotation speed (rpm) : 3600
Dry Weight (kg) : 28
Fuel Type : Petrol
Socket Type : 2 x 16 amp Socket
Hope this helps, oh and a 2 year warranty!
43,329
49,441
Fuel Type : Petrol
thats a pretty impresive spec Simon,
if and when the Kipor turns into a Kipper i could be interested but as my other post....i havent realy used it since my panel was fitted except to riun the aircon.
is it mod or pure sinewave?
cheers
john.
Planetgen
75
Taunton
RV
Hi John, it is a pure sinewave. If ever you see Planet at the shows (usually with motorama or MTC then you will see chargers and laptops all plugged straight into the Generator, shows we have faith!
Someone that sells Kipor at the shows today made me laugh today on the phone, I asked him if he was having power at the show. He said no, as the Generators are too b****y noisy!
Did make me chuckle!
Si
markymark
241
25
Si would that make your design an open framed one or a suitcase thingy?
Your number is in my phone, i am liking what i see.:thumb:
Cant ring now as Mrs in from work, she will feel left out as i am not giving her all my attention and i am more bothered about MH than her:ROFLMAO:
Planetgen
75
Taunton
RV
Hi Mark, I understand completely. I am quite lucky in the fact mine works for me (In English she tells me what to do!)
It is a suitcase type, open frames are too noisy!
Ckeck out the site if you want, lots on there.
Simon:thumb:
Planetgen
75
Taunton
RV
Thanks, she would kill me is she saw that! she does earn more than minimum wage, however she seems to earn more than all of us!
Linda and Steph
Jun 18, 2008
1,588
2,281
Lancaster
None
Since June 2008
A bit of a silly question I think; but where do you store a 28kg gennie? Also, according to HSE guidelines, the upper weight limit for a one-person lift is 25kg :whatthe:
This won't stop me eventually buying a gennie but the weight factor isn't something I'd thought about until now:Blush:
Planetgen
75
Taunton
RV
In fairness its a good point, yes 18kg is more than a one man lift. Problem is almost all Generators - eg Planet 3 - 28kg, Kipor 2600 - 28kg, Honda eu26i - 61kg! The 3's in any family are heavier. I suppose when I lug one round I am breaking a law? :Doh:
Common sense is required. If injury is going to be caused through lifting it then dont!
I will ask Muscles, (Muscles is our delivery man at the shows, anyone that has seen us at a show will see him wizzing round with a trolley and lots of Generators!) He seems fine!
In terms of storage - you can store in Lockers, Dad stores his in the bathroom, under the bed, even in a corner of the van. Providing the Fuel cap valve and the main fuel valve are switched of then you have aa secure air tight Petrol carrier. We tend to have about 60 Planets in the Planet Show Van every week. I wouldnt get in the van if the fuel was not secure!
Si
