Yearly servicing? (1 Viewer)
Sift
107
63
Ringwood, UK
Since April 2014 :O
Hi all,
Just looking for a view as to whether people get their MH serviced anually? I'm referring to the base vehicle, rather than an habitation areas. My MH only did 3100 miles last year so I'm not entirely convinced it needs another just yet. When it comes to anti-freeze and other fundamentals, I can check those myself and I had the timing belt and auxiliary changed at the last service.
Would appreciate your views.
Regards,
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I have mine serviced annually and the MOT done at the same time. We travel about 5,500-7,500 miles per annum. It goes to a local HGV garage.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Our van is serviced once a year, by Geo at Pecks Hill Garage.
we usually cover between five and seven thousand miles per year.
Brisey.
Sift
Sift
107
63
Ringwood, UK
Since April 2014 :O
Thanks for the replies all. Oil and filter, while having the MOT, makes sense and should hopefully be cheaper than the full shebang.
Regards,
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
An annual service should also include a safety check, corroding brake pipes, splits in tyres you can't see easily from the outside, etc. Service intervals these days are driven by reducing costs for fleet owners who will dispose of the vehicle after say 5 years.
lorger
9,632
90,364
Dumfries
Knaus Sun 650MEG
Always get it serviced yearly at a local family run HGV garage.
Jun 26, 2012
89
57
ipswich suffolk
coachbuilt pilote
2005 off and on
Anyone know of a decent garage near ipswich for base vechicle service of Peugeot MHome apart from Peugeot main dealers thanks
trekkin
332
490
Staffordshire
Rv
5 years but still learning
Serviced annually and MOT 6 months apart so goes in twice a year to be checked over underneath and full wheels off every time.
Piece of mind worth the extra cost.
Jan 22, 2013
1,247
58,430
London SE
A class Adria vision I707
since 1971
Just to add to what everybody has said, if your Motorhome is used infrequently with a low annual mileage then the bi product of the combustion is acids and water, this will accumulate inside the engine and cause corrosion,
Especially camshafts and followers as theses usually dry out if left without a regular run
If you do a high mileage then the high temps will drive our the moisture and keep the acids suspended in the oil,
When all said and done the fifty quid you pay for an oil and filter change is a tiny fraction of the average cost of a Motorhome so why wouldn't you change it annually regardless of use?
Reactions: f6c
