X250 Warnng Light question (1 Viewer)
May 12, 2011
1,188
1,869
West Midlands
Hymer
Just started the van uo and noticed that the scheduled service spanner has come on and the generic failure indication (the triangle) - both glowing a faint amber.
Anyone know if these two lights are linked? the service spanner isn't an issue as the van had a full service recently, it is the other light coming on that is causing concern.
TheBig1
17,630
43,268
the answer is to plug in a code reader, check for listed faults and reset them. if the lights come back on get the van to a workshop for investigation/repair
code readers available on eBay under £20
May 20, 2009
785
865
Haute Vienne, France
From the Handbook
GENERIC FAILURE
INDICATION
(amber)
The warning light turns on in the following
circumstances.
Engine oil pressure
sensor failure
The warning light comes on when the engine
oil pressure sensor is faulty. Contact
Fiat Dealership as soon as possible.
Inertial fuel cut-off switch
intervened
The warning light comes on when the inertial
fuel cut-off switch is triggered.
The display will show the dedicated message.
Rain sensor failure
(versions with multifunction
display)
The warning light on the dial turns on
when the rain sensor is faulty. Contact Fiat
Dealership.
Parking sensor failure
display)
See what described for warning light t.
Hope that helps.
Steve
Detnor
May 12, 2011
1,188
1,869
West Midlands
Hymer
On Friday I rang the local Fiat Dealer, all they could do was 'take a look' in January....could give no advice on the phone.
I rang the Motorhome Depot in Redditch http://www.themotorhomedepot.com/ and they immediately offered to look at it today.
Went in this morning, left it with them for 2 hours and they advised it may be the dashboard. No coded faults being reported on their box of tricks and the checks on the van showed nothing. The 2 lights had now gone out, but they advised they'd done nothing to cause this to happen. Apparently dashboard problems are not unknown!
Anyway, drove away, no warning lights on and so far, all ok.
The charge - nothing, all part of the service.
43,329
49,441
whatever brought the lights on, they shouldnt be glowing dimly....they should both be brightly lit.
looks to me like an electrical fault on the dash cluster/wiring loom.
