X250 scuttle drain improvisation.
Discussion in 'Tech/Mech General' started by Techno, Jan 31, 2015.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    I've yet to strip and seal my scuttle but having seen other peoples methods I believe this is a quite ingenious and cheap alternative.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    More pictures when I do the whole job
    • Like it Like it x 10
    • Informative Informative x 1
  2. Techno
    Jul 28, 2010
    14,189
    15,163
    MKII
    Hozelock type O ring seal giving a no mess solution!
    [​IMG]
    [​IMG]
    [​IMG]
    • Like it Like it x 6
  3. ebo
    ebo Read Only Funster
    Nov 9, 2009
    65
    56
    Essex
    Well done Andy a Great solution to an annoying problem, one that Fiat should have rectified years ago, where did you source the metal circlip/spring clip?
  4. Techno
    Jul 28, 2010
    14,189
    15,163
    http://www.ebay.co.uk/itm/200924680835?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    EXTRA snippet of info
    After drilling the 16mm hole it is best to chamfer the edge at 45 degrees. If you examine a sealant nozzle closely you will see why and then the flange will sit flat to the scuttle.
    [​IMG]
    • Like it Like it x 5
    • Useful Useful x 1
  5. BFM14
    BFM14 Funster
    Jan 24, 2015
    84
    94
    Leicester
    Can you confirm that the scuttle is the area below the windscreen wipers. Where is the drain positioned?
  6. Techno
    Jul 28, 2010
    14,189
    15,163
  7. Neckender
    Neckender Funster
    Oct 15, 2007
    1,285
    1,596
    Neckend or Benidorm
    I wouldn't use a flat spade bit to drill the scuttle as it could snag in the plastic and make a right mess, I would use a proper cutter. I know you haven't drilled plastic in your test piece Techno, but anyone not sure might use spade bit which is designed to drill timber.
    John.
  8. Techno
    Jul 28, 2010
    14,189
    15,163
    • Like it Like it x 2
  9. mick noe
    mick noe Funster
    Apr 14, 2009
    616
    523
    near Boston Lincolnshire
    I have done something similar run 2 hoses fitted from drilled holes next to the wiper blade drive shafts also sealed joint in the centre of scuttle with silicon sealant and windscreen seal pulled away and smothered in silicon grease has worked well so far.
  10. robnchris
    robnchris Funster
    Jan 11, 2010
    1,364
    1,699
    Chester
    I used the same nozzle in our scuttle drain but also added a length of pipe so the water drained below the engine bay away from any electrics.
    A well worth improvement taking less then 30 mins to complete.
  11. Techno
    Jul 28, 2010
    14,189
    15,163
    [​IMG]
    • Like it Like it x 3
  12. Jimbohorlicks
    Jimbohorlicks Funster
    Sep 3, 2012
    835
    1,064
    Cheshire, Treacle Town
    All the posts re the water in scuttles etc prompted me to check mine over -it was sunnier today so had the bonnet up.In my Fiat 130 there is a 25mm dia. (at least) drain hole in the windscreen wiper arm well, with a drain tube that runs through the side of the wheel arch. The drain is located on the offside of the scuttle bottom.
    just in case anyone else wondered if the lack of drainage encountered was for all Fiat engines(y)
  13. Techno
    Jul 28, 2010
    14,189
    15,163
    Yes they are all like that
  14. Jamwitt
    Jamwitt Funster Life Member
    Jun 18, 2012
    511
    246
    Chandlersford
    Does this apply to Peugeot
  15. Neckender
    Neckender Funster
    Oct 15, 2007
    1,285
    1,596
    Neckend or Benidorm
    My 2014 Peugeot Auto Sleeper suffers from the same.
    John.
  16. Neckender
    Neckender Funster
    Oct 15, 2007
    1,285
    1,596
    Neckend or Benidorm
  17. Techno
    Jul 28, 2010
    14,189
    15,163
    The X250 scuttle has ONE drain slightly off centre. Even with a sealed scuttle to windscreen the PROBLEM comes when parked on the opposite camber as the water builds up to sufficient height at the other end to over flow into the engine bay through the bonnet hinge slots before it goes down the provided drain.
    This is mine (LHD so reversed) on level ground so ok but if I park on the wrong camber it is no good.Drain in foreground.
    [​IMG]
    Fitting the improvised drain at the other end alleviates this.
    [​IMG]
    [​IMG]
    Pipe goes to inner wing over wheel arch
    [​IMG]
    The situation is probably worse on RHD versions as the leak will be over the fuse box.
  18. Techno
    Jul 28, 2010
    14,189
    15,163
    Fun member GAVLAD obtained this extra part for me from a Citroen dealer as Fiat plead ignorance of its existence.
    Very easy for me to fit as I have dispensed with my EGR pneumatic vacuum controller altogether now.
    I think they intended the waste pipe to drop down the front of the engine but I found it better over the back of the gearbox
    [​IMG]
    [​IMG]
    View straight up from the ground
    [​IMG]
  19. Neckender
    Neckender Funster
    Oct 15, 2007
    1,285
    1,596
    Neckend or Benidorm
    Not only Fiat plead ignorance I contacted Peugeot in Crewe gave them the part no and they said it didn't exist even though I said I'd seen the packaged part on the internet which was clearly labelled Peugeot / Citroen part.
    John.
  20. GAVLAD
    GAVLAD Funster
    Jul 31, 2014
    650
    638
    West Yorkshire
    Looks good Andy.
    I've ordered my star washers and waiting now for a decent day to fit the extra drains like yours.
    On a separate note, have you ever fit DRL's to your motorhome?
    LED.com have some nice ones which fit into the light recess within the bumper. - I know DRL's is a mucky word to some on here, but thought I'd ask all the same.
