X250 Dashboard access
Discussion in 'Tech/Mech General' started by dna, Jun 24, 2013.
  1. dna
    dna Funster
    Jan 17, 2010
    181
    197
    Cheshire
    Please can anyone advise how you gain access to the offside of the top of the dashboard (to the right of the steering wheel) . I have a mount and mulitpin plug for which I don't have a use and would like to install a satnav / reversing monitor in the same area.
    Having had a look there are screws securing the cover over the instrument cluster and various screws for the covers around the steering wheel and fuse box. There are no obvious screws holding the air vent casing in place.
  2. talaris
    talaris Read Only Funster
    Aug 17, 2012
    89
    25
    Cornwall
    The air vent will just pop out. Needs a bit coaxing but will come out as one unit. It just clips in.
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,545
    9,980
    it needs a firm pull, or take out the instrument panel to gain access. Ive got the service manual for the x250 on dvd, if you want a copy pm me
    • Useful Useful x 1
  4. dna
    dna Funster
    Jan 17, 2010
    181
    197
    Cheshire
    Thank You
    Many thanks to TheBig1 for pointing me in the right direction - much appreciated
    DNA :BigGrin::BigGrin::BigGrin:
  5. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    Whoah there boys, the air vent to the right of the instrument pnel is held in by a T25 Torx screw at the bottom, it is obscured by the oddments box/shelf which is itself secured by a Pozi screw which is obscured by the lower knee trim, this is held in place by two pozi screws and several spring clips. First of all remove the two pozi head scres visible in the drivers oddments box/shelf, then you can pull the lower knee trim away to reveal the screw holding the oddments bos/shelf in place. Then you can attack the T25 Torx screw which holds the air vent in place.
    D.
    • Like Like x 1
  6. dna
    dna Funster
    Jan 17, 2010
    181
    197
    Cheshire
    easy does it
    Thanks Dave.
    That confirms what I worked out from the manual. I will go very carefully and follow the instructions.:Smile:
  7. dna
    dna Funster
    Jan 17, 2010
    181
    197
    Cheshire
    Nearly sorted
    I spent a long time at the weekend working on the dashboard. Many thanks to thebig1 for help with the service manual and to Dave Newall for stopping me pulling too hard on the air vent (That would have been an expensive mistake so I am very grateful)
    My first challenge in following the manual was that I could only see left hand drive illustrations (is there an option to view right hand drive views?). That meant I was searching for a non existent screw near the center console to release the big panel under the steering wheel.
    Having managed that, the storage pocket. pillar trim and the air vent were easy - the manual was correct for them!
    When I get time I will resize and post pictures of the new set up with the Satnav and reversing screen installed.:thumb:
    Thanks again
    DNA
  8. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    thank you Dave for an excellent post
