X250 check engine light.
Discussion in 'Tech/Mech General' started by Bartyfixedit, Aug 18, 2015.
  1. Bartyfixedit
    Bartyfixedit Funster
    Jun 11, 2014
    195
    295
    Maidstone Kent
    Typical, we are just north of Florence and about to head back and we've got a problem.
    Went up into the mountains today and stopped in a little village for half an hour or so. When we came to leave the engine only started on a couple of cylinders, very rough. Gave the throttle a good blip and pulled away and the engine started running smooth as ever. Done 20 miles now and no problem, but of course the check engine light came up and won't clear. Any ideas?
    3 ltr, egr blanked and cheated.
  2. gloworm
    gloworm Funster
    Dec 30, 2008
    911
    1,730
    Cheshire
    Could have been an air intake problem, depends how high you were up the mountains, if the problem has gone the engine light will clear itself.
    Eric
    • Like Like x 1
  3. TerryL
    TerryL Funster
    Mar 5, 2010
    1,404
    1,385
    North East
    Start and stop the motor 5 times - it will probably clear the warning light. Worked for me and a few others I've mentioned it to.
    • Like Like x 1
  4. Zajacp
    Zajacp Read Only Funster
    Sep 11, 2012
    92
    57
    Cheltenham
    As above on and off a few times on the trot and away it goes
    • Like Like x 1
  5. Bartyfixedit
    Jun 11, 2014
    195
    295
    Maidstone Kent
    Started and stopped it five times but light stayed on. Oh well I thought, started it again and pulled away from the campsite. Within 100 yards on a steep climb it cleared. Done 200 miles today and so far all good. Thanks all.
    • Like Like x 2
  6. Ridgeway
    Ridgeway Funster
    Mar 10, 2012
    879
    382
    Lausanne
    Mine came on yesterday when returning home. Stopped and checked the usual suspects but nothing amiss so carried on. No performance change but light and message still on "Check Engine" I've read about there being a code that would diagnose what the actual fault is but haven't got access to the kit to do that. Have only started it once since then when I took it back to storage today so maybe the "5 restarts" will be enough, will try that at the weekend.
    Anyone else have any other experiences ?
    FYI: this is a 150ps 2.0ltr variable turbo version
  7. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,084
    Leeds the one up North
    Your throttle valve could already have damage from pre blanking and or water ingress. It will probably clear itself
    • Informative Informative x 1
  8. Techno
    Jul 28, 2010
    14,138
    15,084
    I think in my EGR thread I still got an engine light on occasion after blanking despite having cleaned the throttle valve.
    It was water ingress in the electrical part that was goosing it.
    I changed the rubbish Whaler unit for a Pierburg and it has been fine since
    [​IMG]
  9. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,087
    2,927
    Kendal, Cumbria
    Any 'fault' that could be either permanent or temporary is noted by the ECU. The ECU will wait until it has logged a number of fault occurrences before lighting a dashboard indicator. The number that have to be logged before an indication is given depends on the importance assigned to the particular fault. The ECU is also capable of logging an engine start, run, then stop throughout which the fault previously logged has not occurred. The ECU will reset the fault count after a certain number of successful 'start/run/stop' events have been achieved. The importance of the particular fault being counted can be used to determine how many have to happen before reset. The ECU is performing this miracle continuously and on most occasions reset will occur before the fault count brings on a warning light. Sometimes the fault light illuminates and some sort of intervention (repair) is required.
    It's worth knowing that most fault warnings mean something has happened that affects emissions. In particular the ultimate fault warning - limp mode - does not exist to reduce the possibility of engine damage. It exists to force a visit to your tame van fixer because your engine emissions are excessive.
    • Funny Funny x 1
