X250 cab additional 12 volt power options
Discussion in 'Tech/Mech General' started by Techno, Jan 7, 2015.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    X250 cab extra 12volt&USB options. THIS is left hand drive so just imagine it transposed for RHD
    First, previous related threads.........
    :-Replacement 12volt sockets
    :-12volt socket permanent live
    So extra outlet options? a bit of dismantling soon finds suitable places but initially I have chosen right in front of the driver so that USB items can be charged while in the storage below the steering column. Also My CHINKYNAV on my DIY mounting bracket will plug straight in with a very short lead.
    [​IMG]
    Removal of the instruments and the radio allows full access.
    A 25mm hole drilled and then filed out to the profile of the USB outlet.
    [​IMG]
    [​IMG]
    [​IMG]
    Important! spray the thread with silicon before inserting or the lockring will be a struggle.
    [​IMG]
    [​IMG]
    [​IMG]
    These positions on passenger side are also suitable
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The best method of adding extra lines off the feed is with these WAGO connectors
    [​IMG]
    • Like Like x 4
    • Informative Informative x 1
  2. Techno
    Jul 28, 2010
    14,140
    15,091
    Instruments removal.
    Remove the T25 Torx screws, one either side of the binacle
    [​IMG]
    Then pull up on the leading edge near the windscreen, it will then pull clear towards you.
    The instrument cluster is held by 2 Philips screws one either end and then it will pull upwards and free.
    [​IMG]
    [​IMG]
    To replace just reverse the procedure.
    [​IMG]
    • Like Like x 4
  3. Techno
    Jul 28, 2010
    14,140
    15,091
    Firstly before I continue, this position is also a suitable candidate in the passenger side shelf
    [​IMG]
    Now if you recall in the thread "permanet live socket" once done one of the original ignition switched socket feeds became redundant. I don't want the USB outlets to be always on so I have utilised those wires using 3 way Wago's leaving a spare connection for future.
    [​IMG]
    [​IMG]
    They then just push into this recess that does not interfere with anything else.
    [​IMG]
    • Like Like x 2
  4. Techno
    Jul 28, 2010
    14,140
    15,091
    So now I have a nice tidy set up
    [​IMG]
    I have moved my journey recorder to the pen tray which now means I can leave it in place as the blinds will close without clashing.
    [​IMG]
    [​IMG]
    [​IMG]
    • Like Like x 5
  5. Margaritaman
    Margaritaman Funster
    Oct 27, 2013
    95
    114
    East Yorkshire
    Great post and Happy New Year Andy. Those Wagos look handy! Chris
    • Like Like x 1
  6. Techno
    Jul 28, 2010
    14,140
    15,091
    To you too! Yes they come in many different configurations, just search WAGO on ebay.
    These are the re useable variety and come in 2 3 or 5 way
    Prices vary dramatically so search well.
  7. Falcon 269
    Falcon 269 Funster
    Jul 11, 2013
    166
    408
    Spain
    Awesome info, Andy ... thanks so much for this and all your other tech threads. Your nickname is extremely apt and thoroughly deserved!
  8. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    421
    393
    Lincs
    Sorry for resurrecting this but I'm planning on doing similar and changing the sockets in the cab (can't believe how easily the power plugs pop out of them! And Mr Stroppy gets, well, stroppy, when his phone/ipad won't charge properly) and while I'm at it adding a second socket in the central compartment. So @Techno many thanks for the guide, I've just got a couple of questions.
    Firstly - these WAGO connectors look good - am I right in thinking that I need a pair of 3 ways and put the feed wires from one of the existing sockets into them and then two more wires from each WAGO (one going to the existing socket, and one to the new socket).
    Secondly - what size wire to the new socket? I'm planning on using the feed from the socket marked 180watt max (I realise that this total power will be split between the two sockets). I was thinking 20amp 1.5mm? Or would 2.5mm be better?
    Thanks in anticipation
  9. Techno
    Jul 28, 2010
    14,140
    15,091
    Yes
    At least as big as existing.
    • Thanks Thanks x 1
    • Useful Useful x 1
  10. Stroppy Bird
    Mar 11, 2014
    421
    393
    Lincs
    Thanks @Techno, all bits now being ordered. Hopefully will finally properly sort the charging of all Mr Stroppys gadgets when on the move.
