X250 Alternator fail (1 Viewer)
Techno
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Thanks Jock
Text says delivery within the hour. Now the dilemma , do I go out in the freezing cold or leave it :xlaugh:
On my Apple Watch :xcool:
JockandRita
11,462
150,079
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Thanks Jock
If you were down here, you'd be out there like a shot. It's quite balmy here Andy. Rita has just gone to hang the washing out, wearing a short sleeved top.:xwink:
I hope you and Jacqs are still able to get away. Good luck with the fitting. :xThumb:
Cheers,
Jock. :xsmile:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
How fast is that for ordering at near 5 o'clock yesterday
EDIT for reference this is sold as A3060 and replaces a multitude of original equipment.
BOSCH 124325122
BOSCH 124525064
BOSCH 124525125
BOSCH EXCHANGE 986049950
DELCO EXCHANGE DRA0015
DELCO EXCHANGE DRA0039
DELCO EXCHANGE DRA0245
FRIESEN 9049950
HC CA1913IR
HC CA1915IR
IVECO 504057813
IVECO 504087183
LUCAS EXCHANGE LRA03060
LUCAS EXCHANGE LRA03061
LUCAS EXCHANGE LRA03063
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is the essential tool from the kit I bought earlier in the thread on eBay for clutch pulleys
Lenny HB
53,408
149,870
On the coast in West Sussex
Hymer B678 DL
That's great, should be up and running by lunch time then.:xThumb::xThumb::xThumb:
What's that about freezing cold bright & sunny here, I'm in a short sleeved shirt & no heating on, but the is a bit of a gale blowing.:xrofl::xrofl::xrofl:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes my old one had that too but it it was never connected by the installer
The new one doesn't have one
Steve
1,613
2,062
Compton Berkshire
C class
on and off for 40 years
it is possible that had i fitted it then the alterator may have survivied but will never know. it get get very hot as the windings are burnt. I hope all now goes well for you and have a happy and safe trip.
PS thank-you for some of the must useful advice during the year.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Thanks Steve
I think it unlikely that a low power B2B would be the problem with or without an alternator temp sensor.
My original was 50 amp and the new one 60 amp which should be a doddle for a 110amp alternator.
The best solution when one finally fails is to go straight to 150amp if compatible.
MAE prices are gobsmackingly cheap
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I've just bought a regulator pack for my existing alternator £15 . I'd like to try changing that first as it can be done in situ on mine and if it works I'll have a 110amp bosch for sale in working order.
Both 14mm nuts and one 8mm screw gains access to the regulator fixings
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is a web search image of a 3.0 Iveco WITHOUT aircon.
Replacement of the 6 rib drive belt is straightforwards after taking tension off the belt at the tensioner pulley.
If Aircon is fitted the crankshaft will carry a double pulley and the 4 rib stretch belt for the compressor will be nearest and impede removal of the alternator belt.
JJ
Mágica
May 1, 2008
19,258
48,031
Burstner Privilege T
over 50 years
Reading this thread has reminded me why I, despite serving my time as an apprentice mechanic at Joseph Cockshoots, Bellevue Works, Manchester, now take my van to Rui's garage and let his lads lie around under it getting their hands dirty...
JJ :xcool:
23,768
133,501
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yep most are like that . My car is but only takes a few seconds to remove the A/C belt.
Only in that its all barely an inch away from the chassis rails
& yes car is same to the extent that KIA state " drop engine, gearbox on subframe" to do the cam belt . The A/C belt is below the chassis rails but the auxiliary belt is a remove wheel, inner splash panel,lower panel & then with spanner on the auto-tensioner nut it is all done by feel ,basically. :xlaugh:
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
I've still not gotten around to fixing this yet
The weather has either been wintry or I've had more pressing things to do
First wind rain and snow free day and it may get sorted
JockandRita
11,462
150,079
Lincs/Cambs border
N+B Flair 8000i
Careful Andy, the new alternator will soon be out of warranty before it gets fitted. :LOL:
Weather wise, down this way you could have fitted a dozen at least. ;)
Cheers,
Jock. :)
Reactions: Al1
eddie
8,150
41,220
Taunton Somerset
RV
since 1989
Thanks Steve
The Alternator temp sensor isn't required on motorhome installations. If the B2B was fitted on a boat down in a engine room with little or no air flow it should be fitted
Underneath a modern motorhome there is no need as there is ample cooling for the alternator
We were told this years ago by Charles Sterling when we enquired if it was acceptable to extend the sensor and told not to bother
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Today I thought now or never , very cold but sunny
I have swapped the regulator and it is now working (y) but my fingers are frozen
Found heki is leaking at same time :mad:
I'm going to save the new alternator for future
So effectively under £20 cure and about 30 minutes
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
This is the regulator I sourced on ebay
Broken Link Removed
