X250 3.0 Ducato Wont Start. Any Common Causes? (1 Viewer)
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
Hi all,
I did a 100 mile round trip on Friday, no problems. This morning the van wouldn't start.
I have tried both keys and both are being recognised by the ECU.
Battery is fully charged.
When you turn the ignition on, all is as normal. When you turn the key to the start position there is no click, and the engine does not turn over. The solenoid is definitely not closing as the dash warning lights are not dimming.
Any ideas where I should look first in the morning?
Thanks all,
David.
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
Check out the earth lead, as you look down back of air filter housing there is an earth from body to engine,
Its common for this lead to corrode and break.
Eric
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
Loose exiter wire on starter motor?
( that's the small wire that activates the solenoid) or bad earth?
Dec 27, 2014
967
3,361
Remove the energising wire from solenoid, power it with +12ve and see if it cranks...(make sure it's out of gear).. If not then a starter motor/solenoid fault or earth or main power cable problem.
Best check is a volt meter between battery neg and engine, cranking should show less than 1 volt..... then
Voltmeter from battery positive and starter motor main feed and again should be less than 1 volt on crank.
Could be relay, ignition contact etc....even a battery ! Shouldn't be a problem for any competent auto elec guy if you cannot sort it.
Let us know the outcome.
Bartyfixedit
Bartyfixedit
330
566
Maidstone Kent
Since 1987
Thanks, I'll have a play tomorrow and let you know.
Bartyfixedit
Bartyfixedit
330
566
Maidstone Kent
Since 1987
Thanks very much for the kind suggestions, all fixed now.
Jay gets the coconut! The conductor inside the exciter wire at the solenoid was broken. Typical Fiat, a very skinny little wire in a position of high vibration.
Thanks again,
Cheers,
David.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Glad it's fixed & thanks for keeping us updated.
