would you you use one of these?? (1 Viewer)
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
would you use one of these or plug one of these into your motorhome??
if not why not??
Link Removed
Feb 27, 2011
14,729
75,850
UK
Self Build
No. 2 stroke (Loud) Unregulated. Ok for power tools etc. I would be concerned about the damage it could do to things like my charger etc.
I have the Link Removed Digital one and it's fine for the money.
sedge
Jul 7, 2009
5,504
13,113
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Well if you only need 700w, to power whatever you wish to run, why not?
No idea what sort of equipment you'd be limited to, though, but that is the only snag I can think of, off the top of my non-technical head?
thehutchies
1,527
1,776
The Wheelèd Shed
I have often run one, connected to my 45A intelligent charger, to top up a large battery bank.
It's fine, as long as I first check that there aren't any grumpy owld (or young) gits about.
If someone nearby is making even more noise, then so much the better :thumb:
I did stay on a site once where someone was using one to power their two-man tent.
What on earth were they doing in there? :Eeek:
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
the reason i asked was that i done a run test on one of these and under a light load it was pushing out 290v and under a heavy load not exceeding it's capacity it was running at 180v,and nothing i could do to it would alter that:Eeek:
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Beetn using mine for four years now. Bought it at Netto for £59:00. bit noisey but is ok to keep leisure battery charged and run fridge.
43,319
49,372
with these cheap gennies its the revs which dictates voltage.
with a known load you could adjust the engine speed via the governer to the correct voltage, but change the load and the revs would alter so changing the voltage once again.
it would also alter the wave frequency from the normal 50Hz, so not worth the bother.
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
exactly! i could get it to run at 220/240 untill i changed the load:thumb:
Feb 27, 2011
14,729
75,850
UK
Self Build
45A @12v = 2.25A at 240v = 540W so I guess it will.
But the charge voltage can be 14.5V so 14.5 X 45 = 652.5 Watts. Add some watts on for the charger to operate and losses etc and you would be pushing it I think?
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
If we're being picky, the bulk charge voltage will not be as high as 14.5v and by the time the battery is 80% charged and the desulphating/equalisation phase is at 14.5v the current will be much reduced, so I reckon its quite OK though I agree it may be getting close to the maximum continuous output of the generator.
Feb 27, 2011
14,729
75,850
UK
Self Build
You are of course correct, I didn't think that one through :winky:
I use 14.5 for calculations to ensure I have plenty of headroom. If memory serves by the time my charger exceed 13.8V the current starts to fall.
I don't mind being corrected when I'm wrong :Doh:::bigsmile:
Jaws
23,834
72,435
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Its just a badge job of a cheapy .. I have one you can have for a tenner if you want it Chris.. Think it needs a plug now but I bought it 2nd hand last year to do a couple of jobs out at a hanger.. and although not advised I have used it several times on the motorhome without any sort of problem.. Basically yep, it worked ok
chrisgreen
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
no i dont want it! got shot of one i had give me last year,funny anough that needed a new plug as well:Smile:
darklord
1,241
1,230
essex
coachbuilt
three years
I had one a few years ago, different name on it, bu the same genny. I used it for the caravan, one day the head gaskett went. I contacted the retailer, he said no parts in the country at the moment:Angry:, so I made my own gaskett and it ran OK,ish for a while longer...then i just binned it as pretty much useless.
