oiling and waxing work well on bare wood or wood previously coated in wax etc. the problem is motorhomes are built using lightweight woods that have been stained and lacquered to appear to be more expensive hardwoods. the lacquer is basically a waterproof barrier preventing oils and waxes from getting at the wood. therefore you need to sand the lacquer first
in the pictures above it appears that moisture has discoloured the lacquer with age leading to spotting. in this case, a light sand and a coat of coloured polyurethane varnish or lacquer over the top will cover it up and give an even finish
