scotjimland
- Jul 25, 2007
- 2,324
- 10,055
- A Woosh bang
If it's mission critical.. I would buy Honda ... but for occasional use or just as standby for emergencies..look good ...
Posted for information.. I have no connection with Wolf nor endorse these products...
The range of Wolf Power 'Genie' Inverter Generators not only provide fantastic value for money but gives the user reliable and stable power wherever and whenever it is needed.
Wolf Genie Inverter Generators use advanced 'state of the art' technology which produces a constant voltage and frequency stability of between + or -1%. The voltage stability of these generators is often more stable than the normal mains supply which makes them ideal for operating sensitive electronics such as computers, TV's, DVD's, PA systems etc..
Being very quiet in operation compared with traditional generators, they have a low fuel consumption and develop a fantastic power to weight ratio. Just look at the technical specification below and see just how lightweight this model is. Most adults can even lift one with 1 finger.
The WPG950 Inverter Generator is fitted with a selectable 'econo' switch which allows the generator to idle when no power is being drawn, making it even more economical. Also fitted with a power overload cut off to protect it in the event of an overload, making it virtually indestructible in normal use.
Broken Link Removed
Broken Link Removed
Broken Link Removed
Broken Link Removed
Broken Link Removed
Broken Link Removed
