Wiring in reversing camera
Discussion in 'Motorhome Accessories' started by Stroppy Bird, Sep 15, 2014.
  1. Stroppy Bird
    Stroppy Bird Funster
    Mar 11, 2014
    430
    401
    Lincs
    My reversing camera has turned up today. I am intending on using it with my garmin sat nav and have the appropriate lead to connect the av cable to it.
    My question is this - what is the easiest way of picking up the 12v power for the actual camera.
    I know it can be done by using the +ve to the reversing light - but how exactly do I do this? My van is a 2010 Fiat Ducato. I've had a look at the rear lights and presume that somehow or other I need to connect to the correct wire in the electrical block that is connected there - is this how others have done it? There is already a bolt to the chassis near the lights that has a couple of wires attached to it - I'm thinking that these are the grounding ones and I can just connect the camera -ve to this.
    The alternative is that the av cable also has a trigger wire running through it. Would this be able to be connected to the camera +ve and then to another +ve at the monitor end to provide power as and when required? If so is there such a thing as a male cig lighter that has an input for just a +ve wire - most seem to have inputs for +ve and -ve?
    I'm trying to not over complicate but seem to be going round in circles at the moment on this one!
  2. ericroy
    ericroy Funster
    Sep 22, 2013
    103
    77
    Staffordshire
    When I fitted my reversing camera to a 2014 Citroen Relay (should be almost identical to yours), I used the auxiliary socket in the rear off-side corner as the 12v power source and connected the earth return to the bolt earth-bonding point you have described. While this may not be ideal for everyone, I wanted a simple approach that brought all the connections from a single location and did not impact the vehicle CANBUS. I used a meter to identify which was the feed to the reversing lamp so that this could be used to trigger the reversing camera.
  3. iceni
    iceni Read Only Funster
    Dec 3, 2007
    301
    115
    Birmingham
    I would locate the rear light cluster and find the rev live feed and then scotchlock or use a doubler bullet connector to connect the rev camera wire into it.
  4. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
  5. steevie
    steevie Funster
    Apr 29, 2012
    296
    269
    Holmfirth
    I have mine on a switch, which is connected through the fuse box. That way I can use it anytime to check whats behind me, mainly because I do a lot of towing, but also to see whats happening behind at other times, without having to put it in reverse. Down to preference I suppose.
  6. movan
    movan Funster Life Member
    Dec 2, 2009
    13,977
    25,438
    Moving around
    give Terry or Andy63 a private message and they may be able to help you. :)
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,201
    3,028
    Kendal, Cumbria
    Run the camera power wiring alongside (taped to) the video lead to the front. Once you have it under the dashboard you can choose either a simple switch as suggested or you can connect it to the reversing lamp wire as it heads off from the gearbox switch towards the rear of the van.
