Winterising Hymers.
Discussion in 'Top Tips & Tricks' started by MrsBB, Dec 8, 2014.
  1. MrsBB
    MrsBB Funster
    Jun 14, 2014
    87
    46
    Derbyshire
    Got alde system and a 300 page hymer manual plus several other manuals . Some of the suggestions are really OTT .... Maybe this is because it is designed for Germany and places even colder . It says take out TVs , completely empty all upholstery, any other loose fixtures and fittings including gas bottles whether empty or not!
    We don't live in a mansion with several spare rooms and the ones we have are already full of junk ( says he!)
    We can leave it on hook up but is that an unnecessary expense?
    Any help gratefully received.
  2. dabhand
    dabhand Funster Life Member
    Feb 19, 2014
    1,656
    2,922
    Staffs
    Never bothered with any of that in 20 years. It's sensible to remove bedding and food cos of the dreaded meeces and drain down the water if it's going to freeze as a blown water heater/tank would be expensive to replace, although I don't even do that, as the boiler has a dump valve for when it freezes. A little heater with a frost setting is good, or you could just use your van through the winter? I leave my van plugged in all the time and when I remember unplug it for a couple of days to give the batteries something to do!
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    29,040
    25,730
    Suffolk
    not so daft..
    Samsung LED TVs have an operating temperature range of 50° F to 104° F (10° C to 40° C). Temperatures outside this ranges will affect the operation of the TVs and can cause damage.
    Storing below zero may also damage..
    Google throws up some more info ..
    just one link of many http://everydaylife.globalpost.com/led-flat-screen-tvs-freeze-cold-weather-39273.html
    and if you live on a council estate they will get nicked.. :rolleyes:
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    Might be worth taking out a TV (I never have), but the rest is probably not necesary unless the temperature falls significantly below zero.
    My list is as follows. Ensure the fresh water has drained out of the taps (leave them open in the central position). All water tanks empty (but I drain down after every trip anyway). Leave the locker and cupboard doors open to ensure free air movement and to prevent the cushion pads sticking to the frames (mine are now 11 years old). My batteries are kept topped up anyway by a solar panel so no need to keep it plugged in to mains electricity.
    If it gets really cold for an extended period (say -5ºC or lower) I sometimes put a 500 watt Dimplex 'Cold Watcher' heater in the van and plug in the mains.
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,918
    17,633
    notloB
    If you have "wet" central heating as in Alde make sure there is antifreeze or glycol in the system specially if it's a few years old. In our static we use Sentinal R500 or you can use R600 ( other manufacturers are available :D ). I take ours down to -20 as we had a -17 week in 2010:eek:
  6. s20hymer
    s20hymer Funster
    Jun 11, 2011
    276
    332
    Wiltshire
    hya fill sink and shower traps with an anti freeze screen wash if they freeze they split on some hymers you have to take shower tray out to replace the traps
    • Like it Like it x 2
  7. Badknee
    Badknee Funster
    Aug 25, 2014
    3,918
    17,633
    notloB
    Ha, anti freeze screen wash. While in Canada in the winter of 2012 I asked about window wash and they use it neat and it was working at -27c. I checked it out here at Halfrauds and neat was guaranteed down to -7c :LOL:
  8. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,370
    14,514
    Bolsover, Derbyshire
    Mrs BB take the easy option, if you have hook up at home, we plug in set temp to 10C don't drain anything, always ready to set off if we fancy (y)
  9. dabhand
    Feb 19, 2014
    1,656
    2,922
    Staffs
    Oh! And re TV mine has a cover made out of silver screen material, don't know if it makes any difference but it keeps it clean!
