Winter & water in RV
Discussion in 'Full Timers' started by Mikey RV, Nov 30, 2010.
  1. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,136
    3,238
    Devon
    How to folks manage with water in the rv when its freezing outside. Our hose has froze but got water in tank so is this ok, whats the chance of the water tanks freezing and will pump be ok. Dont want burst pipes and big repair bills. Sure there are RV owners out there living in colder parts of the country than me.
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    We've had two RVs now, first was a tas old but on both we didn't have fresh water freezing problems with the fresh tank being in doors, so as long as we're in the van and have heating on all has been fine, fingers crossed:Doh:
    The grey and black are a different matter. They were/are external and yes freezing is an issue. The first van had small tanks so didn't give much bother but Winne's are larger and we've had the bottom of the grey freeze and the pipe to the dump valve and the black freeze but just around the valve. This happened twice last year, but thankfully we, or rather Winne survived. First time was so bad it took and hour with hot water through a hose to defrost:Doh:
    I keep thinking about lagging and heaters but I can't make my mind up as yet how to go as there are a number of option:Doh:
    If all tanks are effectivly internal I gather some have found running a small heater in the relevant locker works or adding an additional duct from the furnace to the relevant locker works too.
  3. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,136
    3,238
    Devon
    WOW... 53 views and only one reply. Is everyone gone to hibernate away from the cold, wish i could. :Cool:
  4. Colin and Jaen Andrews
    Colin and Jaen Andrews Read Only Funster
    Aug 18, 2008
    200
    34
    Gloucestershire
    freezing
    we full time and cant get any water at moment:Rofl1: - fortunately have half full so will cope.:thumb:
    Scared to say never had a problem emptying grey and black as due to try 2 morrow.
    Who knows - its our day off site and after the last couple of days anything could happen.
    Fingers crossed plus everything else - but all part of full timing - you deal with it and smile:thumb::thumb:
    jaen xxx
  5. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,285
    16,958
    Liverpool.
    All my RV tanks are inboard inside a double floorspace,all underneath the RV has been sprayed with expanding foam including the diesel tank,so it has to be very very cold for the tanks to freeze.I do have 12 volt fishtank heaters fitted to the tanks but didnt have to switch them on last winter,and it was -12.I do have a problem at the moment with my VW even though I drained it down there must have been water in the pump,so at the moment thats not working.Will have to see what hapens when the thaw comes.:RollEyes:
    Best of luck.
  6. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Pull leaver gently and you'll soon realise if either is frozen.
    Our second freeze, going for a drive sorted it, combination of heat wafting under the van from the engine etc and shaking about I guess.
    Mind you there was a couple of disturbing plops before full flow was achieved:Rofl1::Eeek:
  7. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,919
    Norfolk
    My last RV and the new one both have inboard water tanks and plumbing, the black and grey tanks are underfloor and open to freezing but both being Four Winds have the optional 12v heatpads which can easily be retro fitted . Laracroft has some for sale on rvoc for £35 each. They stick easily to underside of tank , then all you need is a 12v fused switched supply.
    Beware if you have an outside shower , mine is in a little locker which I have filled with material insulation.
    Check that plumbing is inboard in which case you should be ok
    Larry
  8. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Ooooh, outside shower, we got one of them and it's never crossed my mind:Doh:
    Obviously drain down when I feel freezing could be an issue but never thought about freezing during van use.
  9. ninjayorkies
    ninjayorkies Read Only Funster
    Mar 28, 2010
    533
    148
    Lutterworth
    - 11 here in the Black Forest and my waste tank/pipe has frozen. Meant to leave the tap open but forgot, only a few buckets of water in there so keeping my fingers crossed all is ok :Doh: Fresh water tank is fine but can't use water pump as I have a leak so having to fill bottles and keep them in the van. Trying to get 2 litres of frozen solid water defrosted for a cuppa was fun this morning. Now I know why people bog off to Spain :Rofl1:
  10. wp1234
    wp1234 Funster
    Oct 23, 2009
    117
    Anglesey North Wales
    Just got back from Bath brrrr it was cold . Spent three nights there and ok up to the last morning when we woke up to a frozen fresh water tank/ pipes . No damage thank god and once we got underway it all thawed out Ok .
    So am now thinking what I can do to put heat into or around the tank for the next time.
    Any ideas out there that are easy to fit on the drive ?
  11. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,371
    1,456
    Suffolk
    both our grey tank dump valves were frozen on Sunday-----tanks were not full, but I didn't want to find them full when it was snowing !! Just a few minutes with a hair drier sorted them out !!
    If it's not too cold ! tomorrow I MAY have a go at black tank--------that one is not so critical as we can go more than 2 weeks-----but I don't want to get caught short ! !
    With our fresh water-------I unroll lay-flat hose 1 section at a time---starting at the tap---with the water running, to stop the hose freezing.--------------------when tank is full---take off first section starting at tank end, roll up before it freezes---when last section rolled up--turn off tap---------a right palava, but once hoses freeze, it's very hard to thaw out !
    We also keep a can of fresh water inside-----after getting caught with no water for tea in the morning last winter !! (with our old 5er)
    Our present RV has the pump in the back of a cupboard---so at night we leave that door open.
    We have 'tank heater' but I still don't know if it's just fresh water tank-----or all ?????
    The joys of fulltiming !!!!!!
    Nigel-
    BTW DONT use macerator if it could have ice in it--------I had to strip mine and replace impeller last winter !!
  12. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,898
    13,919
    Norfolk
    Our last RV was a Four Winds Hurricane, on the warm air heating system there was a small, about 1" diam pipe on a junction from one of the main heating pipes, which led into the area around the water tank, just enough to keep the frost at bay.
  13. poacher
    poacher Read Only Funster
    Aug 10, 2008
    26
    Keeping the tanks liquid !
    Our solution to 'cold' nights and keep things liquid - although much of the plumbing is lagged
    we put a 'spare' fan heater with frost stat on low heat in the plumbing bay
    Although we have a blown air vent in the bay from the upstairs furnace - this is only effective when that furnace is in use - it wakes up S.W.M.B.O. when it fires up during the night - the extra fan heater causes me less grief :thumb:
    (Considered the 'greenhouse' heater, but felt that with our fresh, grey and black tanks sat amid-ship, I wasn't convinced that the 'warmth' would get from one side of the bus past the tanks to the other without some assistance - all our 'hook ups' are on the opposite side of the RV from the space where the fan heater can sit safely (atop my tool box)
    We have 'free standing' tubular heaters in the remaining 2 belly lockers - free standing as in they and the guard are mounted on boards, which we place in the lockers when the temperature drops but are able to store elsewhere during the warmer months
    We 'run' all the below floor heating via an 'unrolled' :Smile: extension lead from a second hook-up on those days / nights when it is needed - this allows 'normal' life and power consumption upstairs - and we therefore only pay for the extra heat when it is needed - it is IMHO a much cheaper alternative to potential repairs
    When temperatures drop, we disconnect and drain the fresh water feed and grey / black connections and use the tanks - reconnecting when necessary during the day in order to dump / refill
    Sorry forgot to include - similar thread running on another of the forums
    http://www.rvoc.co.uk/forum/rv-general-chat/2754-heating-in-the-lockers-when-cold-frosty.html
    poacher
  14. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,136
    3,238
    Devon
    Thanks for all the replys guys. Something tells me its gping to be a long winter in the RV. Need to clear up them debts so we can head for the sun this time of year. I hate winter. :Cool:
