Winter storage drainage problem.
Discussion in 'The Beginner' started by Steve826, Oct 11, 2016.
  1. Steve826
    Steve826 Funster
    Oct 11, 2016
    12
    8
    Blyth, Northumberland
    Hi.
    I have recently bought a Swift Kingsmere 590RL year 2000.
    I've been trying to drain waste water and it has 3 black 3" dia caps that needed removing. I have undone 2 and drained them but the third under the sink unit will not undo. The caps are a "bayonet type" that need a half turn to remove.
    My question is has anyone any tips to remove it, or can I just put antifreeze down the sink to stop it freezing?
    Any help would be appreciated.
    Steve
  2. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    I've never heard of a problem with drain's freezing and never had a problem. Why do you feel the need to drain the sink traps?
  3. Steve826
    Steve826 Funster
    Oct 11, 2016
    12
    8
    Thanks for reply. I understand that any water trapped can freeze, then thaw and expand and crack the pipe.
    I presume this can happen if there is any water trapped between a wastewater downcomers and wastewater tank.
    Do you not agree Steal away?
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,679
    Bolsover, Derbyshire
    I agree with stealway, dirty water will still possibly freeze, although inside the motorhome is fairly unlikely except extremes
    The problem with pipes freezing, particularly supply pipes, is that the water has nowhere to expand to, unlike the waste system which can expand fairly freely without damaging the pipework (y)
    remember to open all taps when done, that is a much bigger risk of damage, leave the taps open and any residual water will push out the end rather than splitting the tap, most of us will have done that at least once :(
    • Like Like x 1
  5. Steve826
    Steve826 Funster
    Oct 11, 2016
    12
    8
    Thanks guys. Assuming as i live in the North East we don't have this extreme freezing weather!! this motorhomefun forum is proving worthwhile already and I only joined this morning!!!
    • Like Like x 1
  6. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    you only get a limited number of posts as a newcomer its well worth the £15 subs to be a member
  7. Garfields
    Garfields Funster
    Jun 12, 2016
    78
    42
    Scottish Borders
    Steve826
    You may not get severe frost every winter in Blyth but you do from time to time.
    If you can't drain all the water out your tank add some antifreeze or salt.
    As others have said make sure all fresh waters is drained and taps and showers left open half way between hot and cold.
    Also empty toilet cassette it can definitely freeze and crack
  8. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,679
    Seriously??
    I have never heard of a cassette cracking due to frost, there would be so much expansion space upwards that would be a serious frost, however I have cracked my flush pipe work when I thought the pink stuff would protect it, let me tell you it doesn't
  9. Garfields
    Garfields Funster
    Jun 12, 2016
    78
    42
    Scottish Borders
    David
    David
    Yes seriously
    We are not that high up and have had -18c
    Not every year obviously I think last time was 2010 or 11.
    Its not just the expansion thats the problem a lot of plastics that normally have a bit of give become brittle with the cold.
    Last winter we never had much frost that would cause concern but I like to err on the safe side when I can.
  10. TerryL
    TerryL Funster
    Mar 5, 2010
    1,365
    1,338
    North East
    PLEASE don't put antifreeze in the freshwater tank! I know the post says waste water tank but people have mis-read things before..................
  11. autorouter
    autorouter Funster
    Apr 27, 2016
    123
    48
    Manchester
    About the best advice I can give on winterizing is - don't listen to anything I say. This time last year I made up a clever gadget to blow air through all the pipes and clear out all the water. It worked superbly, except I forgot to blow out the pipe to the toilet flush, and didn't run the pump long enough to get rid of all the water in it.
    Result: new pump and new toilet solenoid valve (which requires dismantling the toilet).
    In the northern US, where they have serious winters, they use an food-grade anti-freezing additive in their freshwater tanks of their 'RVs'. I've never seen it over here. Anyone know what they use?
  12. Steve826
    Steve826 Funster
    Oct 11, 2016
    12
    8
    Your helpful advice and comments have been most welcome. So much so that's I've invested £15 in a years membership. Now looking forward to the dewintering advice next year and the Motorhome fun continuing!!!
    • Like Like x 1
