Winter solar panel charge rate (1 Viewer)
GRUMPY OLD GIT
May 8, 2011
115
227
Pembrokeshire
coachbuilt
Started in1974 with a converted London ambulance
I have 2x80w solar panels on my MoHo,they are linked to 2x85amp LB's through a 20A C2430 Solar Controller using 6mm cable.
I fitted it all about 18 months ago and all has been fine with periods of up to 6 weeks off grid in Portugal last year.
Went to storage last week and LB's down to 11.5v and contoller showing low battery and no charge(low winter sunshine). Took her out for the day,,,,,70 odd miles and batteries back to normal. Next day down to 12 .3 v and contoller still showing no charge,checked all wires and connections,all good.
Multimeter reading showing between 1.5 and 2v from panels but no charge to batteries.
Do l suspect my controller or am l expecting too much from solar in low January sunshine.
Any help/advice or even the usual derogatory comments appreciated
Cheers Bob. :thumb:
JockandRita
11,462
150,126
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi Bob,
We have a similar size solar set up, and I've been getting 1.5A when the sun has been out, and 0.5A when overcast. Both the leisure and starter batteries are showing a full charge by mid afternoon. :thumb:
Have you checked the fuse between the solar controller, and the batteries. When ours blew, (unknown to me at the time), I got amps and volts readings on the controller, but no sign of charging, which then led me to the fuse. :Doh:
HTH,
Cheers,
Jock.
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Had a similar problem with my panel. If you disconnect the solar regulator, on a bright day you should have anything up to about 20volts out of the solar panel. If it's ok try a spare reg if possible. The regulator is probably a shunt type. These effectively short out the solar panel as the voltage on the battery rises, does this to control the charge.
I had a bad connection on a plug and socket located just as the cable comes throughout the roof. Found it by leaving the regulator in circuit and waggling the wires until located. Sounds very much like a hole in the wiring between panel and regulator.
Some regulators have a fuse built in if this was gone then panel volts would be more than you measured in bright light.
Good hunting
