Winter habitation antifreeze
Discussion in 'Motorhome Chat' started by Vlad The Impaler, Sep 16, 2012.
  1. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,192
    Rutland
  2. lorger
    lorger Funster
    Jul 11, 2008
    6,343
    7,796
    Dumfries
    Never seen this product before but wouldn't you have to flush it through before using for drinking water if so then i assume you would be quicker emptying in first place just a thought.
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    I wouldn't like to use it in the drinking water system without a thorough flush through. We've always just drained down well and then refilled when we go away a couple of weeks later.
  4. Vlad The Impaler
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Never drink water from tap anyway usually carry separate bottles for drinking.IWas just thinking that I may be able to use van in colder conditions ie sub zero temps without freezing up as its a Brit van not a continental.
  5. GJH
    Aug 20, 2007
    27,349
    34,968
    We used our previous (Brit) Autoquest 100 in freezing conditions a number of times without any freezing problems. We always had hook-up and used a small oil-filled radiator overnight but that was as much for our comfort as anything else.
  6. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,619
    5,690
    Yr Wyddgrug
    I don't allow water to stand in the tanks for more than a few days before I completely empty them (even in the summer). I don't like the idea of having a shower in water that has stood for weeks. Like you I use bottled water for drinking.
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    this stuff is for long term winter storage....not for intermittent use.
    you never get ALL the water out at draindown.
    you generally need to drain down then introduce the antifreeze neat, pulling through the taps to ensure it is fully distributed.
    come spring, you simply pump it back into its container for next year and completely flush whats left in the system with water.
    many american dealers sell it in boxes of 6 x 1gallon containers due to the amount used.
    http://www.marinepowerservice.com/BoatingStore/browse_detail3.cfm/productID/4295.cfm
  8. GJH
    Aug 20, 2007
    27,349
    34,968
    When we first had a van we drank from the tank but then stopped and started using a separate container which we filled from a tap. The reason we stopped was a TCP type taste resulting from cleaning tablets and/or cleaning fluid in a temporary supply.
    Fine until Stratford show last year when water was delivered in a bowser - with some sort of cleaner in it :Doh:
    So, we bought a filter jug from Asda and filter all our drinking water through that :thumb:
    If the van has stood for more than a week, though, before a trip I drain the tank and refill it. If it has stood empty for a while over winter I'll use some cleaning tablets/solution and pump it through but otherwise the water system is fine.
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    personally I'd never use it, think of the harm it could cause wherever you finally drop it. whilst you don't use the tank for drinking you do wash up from it. not worth the effort we always drain down and use bottled water in the winter.
