Winter drain down Rapido (1 Viewer)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
With overnight temps forecast for -5 i tried to drain down following the manual. Can anyone tell me how to access the shower air trap....u-bend.
It says in the manual to empty and clean.......how???
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
If you don't get it solved tonight maybe you just leave heating and hot water on.
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
I have a 2004 Rapido.my shower trap is under the van.you just twist it anticlockwise and wipe clean.some water will run down your arm:) you should have a fresh water drain as well.open all taps let water drain.then leave taps open and run pump for a few seconds.Also drain heating boiler.depending on heating system
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
It has a double floor Sandra so i'm not too worried but i just don't know how to access it. I have read the manual inside out.......it says to drain and clean but nothing about access.
It is pretty much sheltered, between 2 buildings and in front of my garage........but i don't want to take the chance if i can avoid it.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
As above, i have a double floor, can't find my way to it. Everything else drained as per Rapido.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Mine is not built to be accessible. If your manual says it is then there must be an access panel or it is utter bo**ox
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
To be honest I don't drain the
To be honest I don't drain my trapvery often ,the amount of water in probably around a egg cup full.and mine is not double floor.just open to elements and never had any freezing problems.In my manual it shows my fresh water drain as being next to water tank.guess what.I have to remove a drawer under oven to reach the drain tap:)
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
The manual says it should be cleaned regularly and emptied for winter....???
Techno
Jul 28, 2010
15,475
20,756
May 2010
That says under the sink not the shower tray
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I reckon that is lost in translation. The sink is has its own. According to the data sheet there should be three traps. Shower, washbasin and kitchen sink. Got the other two but fecked if i can get near the shower one.
Edit, the data sheet is pointing to the shower tray.
Apr 15, 2015
610
1,064
Whitchurch, Shropshire
Carthago E-Line 50
Since May 2011
You could put some undiluted screen wash down the plug hole. That will stop it freezing... unless it gets down to minus 20. Even diluted 50/50 should do it.
Techno
Jul 28, 2010
15,475
20,756
May 2010
There is a full stop and then a new sentence referring to the sink not the shower. You don't have an accessible trap on your tray otherwise you would have found it.
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
Give Brownhills motorhome at Newark a call.I am sure someone should be able to advise you
Techno
Jul 28, 2010
15,475
20,756
May 2010
Could there be a remote air trap for the shower below the floor under the sink?
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy if you look at the data sheet it points out three. One at the kitchen sink. One in the WC washbasin and one in the shower tray. See attached photo
Techno
Jul 28, 2010
15,475
20,756
May 2010
Your van is almost identical to my 7090F and I have no access beneath the tray
Techno
Jul 28, 2010
15,475
20,756
May 2010
The only way to access my trap is to remove the shower lining wall panels and lift the tray
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Obviously not meant to be accessed, i'll see what they have to say about it.
I wouldn't imagine much damage, if it ices up, as it is only 10 mm of water in the flat of the trap with plenty of expansion space.
TheBig1
17,630
43,266
to drain my rapido water tank, you get into the garage, remove a clipped in panel to access the drain tap
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
That isn't the purpose of the thread.
See post 1
Found this in the manual, it will probably be obvious.
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I have a Rapido and haven't drained the traps in the 9 years I've had it. There's not much water in them but if you're worried about them freezing stick a bit of winter screenwash down them, as someone suggested earlier.
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
Never heard of anyone draining traps? even if the small amount of water froze it cannot do any damage as there is room for expansion. Would recommend @Techno system of using air pump to remove water from pipework then leave taps / boiler vent open never had a problem.
Jan 3, 2008
3,339
5,357
Pakefield, Lowestoft, Suffolk, UK
Looking
I remove the chrome cover on the trap, lift out the innner plastic piece and then use kitchen to soak up the small amount of water in the trap. On my 9048 there is no other acces.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Update...... I phoned Rapido tech dept in France....... Basically you can't access the trap to clean or drain it. The advice was it doesn't need drained for winter because of double floor.
To clean i was advised to use a propriety plastic pipe cleaner.
