winnebargo water fill (1 Viewer)
pkurzok
60
australia
a class
hi guys
i am thinking of changing my coachmen to a winnebago, but not sure if the winnebago has a filling system similar to the coachmen for taking water on board using the on board pump if there is no hose connection.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
Well my one has
My Winnebago aspect (see photo etc., in red link below post) can take water on via a hatch in the side that allows a normal house hose to fill the RV domestic tank. It also has a city hook up on the other side if I do not want to use the pump.
Bob:thumb:
Jim
Ringleader
Jul 19, 2007
36,312
130,208
Sutton on Sea, UK
Adria Panel Van.
Since 1988
The vast majority of RVs will have a city water inlet. Its the omission of a regular gravity fill on some that are a problem. Our Georgie Boy had one filly point, turn a knob one way and you were filling the tank, another and you were on city water, using teh water pressure rather than your own pump. This however meant that filling with a watering can was almost impossible.
Nov 6, 2008
3,943
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
My Winnebago/Itasca has city fill and tank fill with a hozelock snap connector in the service locker, and a gravity fill, suitable for hose or watering can, on the other side straight into the tank.
Craig
eddie
8,141
41,173
Taunton Somerset
RV
since 1989
My Minnie Winnie has a city water/tank fill and also has a gravity fill in the side of the RV. It is also for sale as it happens:winky:
Eddie
slobadoberbob
6,151
1,960
25 years & counting
oportunist
Mine is for sale too.
Craig
Some people are an opportunist Craig:ROFLMAO::ROFLMAO::ROFLMAO:
I think you will find most Winnebagos have both types of water fill.. saves all the problems of high pressure etc.,
Even my Champion (Titan) had the same and that was well old.. bit like me in a way:Sad:
Bob
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Could I be reading the original post incorrectly. As I read it he can currently use the onboard pump to suck water up from an outside source. Of course I am probably misreading the post, would not be the first time, hee hee.
slobadoberbob
6,151
1,960
25 years & counting
I agree rodger
I agree Roger reading it again.. but the tank fill on a Winnebago is fairly high up.. i use a hose or a small submersible pump in a large container of water which you have seen me at shows filling up.. then I up load that to the tank... at Shepton I use the hose.. but the point I think the question was about is the loading of water under pressure of can it be loaded by a standard hose... may be wrong.. but I have a feeling that is where he is going.
Bob
eddie
8,141
41,173
Taunton Somerset
RV
since 1989
I like Bob fill using a pump from time to time.
We we go to shows and I know that I will be ensconced in the traders area I simply have four 25L tanks in the rear locker adjacent to the wet locker.
A submersible pump dropped into these four tanks whilst they are still in the locker, the outlet pipe into the gravity feed water filler on the side of the Winnie and the 12 volt plugged into the 12 volt socket in the wet locker and I easily pump 100L of water into the on board tank in the time it takes to have a cup of coffee!
This arrangement means that Mrs Van Bitz can wash her hair and shower to her hearts content, which in turns means that me "Cheifwasherupperandfloorscrubber" minion gets a better life:thumb:
Eddie
P
pkurzok
60
australia
a class
misread
that is correct i can use the on board pump to suck. so i can bring my 8 gal drum to side of my van and suck it to the holding tank with my onboard pump. by sounds of it i can do some thing simaliar but i have to buy a 12v pump and find a 12 volt supply to those who offer the van for sale thanks but they are not what i am looking for .
slobadoberbob
6,151
1,960
25 years & counting
these pumps are very small
These pumps are very small and have a hose from the end out to the inlet on the motorhome.. mine is about 4' long and there is a double wire live negative which I have a plug on the end which I connect to the 12v system.. the pump is small enough to go threw the neck of a 5 gallon (25 ltr) container...
Bob
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
This system on the coachmens is slightly unique, and a pain in the arse till you learn how to dial in all the knobs::bigsmile: Ive not seen it on another Mark of RV
Geo
Apr 27, 2008
11,838
14,062
Eastbourne East Sussex
Hymer low profile
Since 1972
I use a submersible pump like Bob, I just plug it in to the 12v socket in the kitchen area by passing the wire through the window. I have an inline bullet switch (same as one some table lamps) so I can turn it on and off without fiddling with the plug. The pump was about a fiver from one of the accessory stands at a show, and I have run the lower part of the hose through a bit of rigid pipe so it sits on the bottom of the water carrier (in my case a 40L aquaroll) as without it the pump tends to float up to the top.:thumb:
