Windscreen Aerial?
Discussion in 'Tech/Mech General' started by rangitira, Dec 13, 2011.
  1. rangitira
    rangitira Funster
    Jun 30, 2010
    6,446
    13,450
    Cornwall
    I need a new aerial on my M/H for the Radio, can't find the end that fixes to the frame, and don't want to go thro the rigmarole of drilling holes in the Body.
    So, braved the weather here in Gods Little Acre, (don't ask!:Angry: Real Poooeee!) and took a turn thro Halfords. Saw one that fixes inside and upagainst the screen.
    Will it work? Saw something similar in a delivery Truck, it was used in conjunction with a Company Radio, a CB style thingee. AND, because I'm only receiving a signal, do I have to do as the instructions say, earth the braided wire, and connect to a live lead? (and YES! I know! "When all else fails read the instructions!":thumb: I did:thumb: thats the scary bit:Blush:)
    All advice gratefully received and much appreciated
  2. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Never had much luck with windscreen fitted ones.
    Give it a fair chance and follow instructions, at least then you have tried.
    Best of luck.
    • Like it Like it x 1
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i would earth the braid.
    and the live feed can be found on the back of your radio will probably say ANT or AMP on it and most likely be blue or could be blue with a white stripe and only be live when the radio is on.
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,290
    16,963
    Liverpool.
    I used to have one in the RV and it worked fine. It was wired to the ignition so as not to drain the battery. It had some kind of amplifier in it and a small red LED came on whilst it was working.
  5. rangitira
    rangitira Funster
    Jun 30, 2010
    6,446
    13,450
    Cornwall
    Thanks Fellas, knew you'd come thro, much appreciated!:thumb:
  6. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    I had a car with one, was OK on it...............doing my head in trying to remember which one it was now...........:Sad:
  7. peejay
    peejay Read Only Funster
    Jun 20, 2009
    34
    25
    South Cheshire
    I have a windscreen arial on my SURE Highway D A B radio absolutely marvelous, best thing ever bought for my works van. Uses the built in radio, wirelessly, only way to listen to Planet Rock when driving.
  8. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
  9. rangitira
    rangitira Funster
    Jun 30, 2010
    6,446
    13,450
    Cornwall
  10. rangitira
    rangitira Funster
    Jun 30, 2010
    6,446
    13,450
    Cornwall
    Job done!:thumb: Works brill :thumb: Especially the bit from techno 100:thumb:
    Once again Cheers M'dears:thumb:
