windows leaking (1 Viewer)
herbies
123
24
somewhere in south devon
hymer b694
my 1995 hymer b694 on removing the carpet stuck to the wall under the front sliding cab window i was horrified to find it wet and the inner ply coat completely rotten i was told by the dealer that this is a common problem in older hymers and nothing to worrabout
i now need to scrape the old ply off and gewt it dry and have new covering fitted but does any one know how to prevent this from happening
cheers Herbies
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Before you do repairs............ fix the problem..
Maybe seals round window have dried up or cracked, or the drain holes at the bottom of the sliding window may be blocked.. Good luck.. :thumb:
Nigel67
98
82
Devon/Cornwall border
Hymer b544
since 2003
I have a 1995 644 and I can tell you what the problem is as I have recently done both of my front sliding windows after one side was getting damp in the centre of the side wall underneath the bottom of the window. I assumed at first that the window mastic seal must have failed so I removed the inner trim then all the metal retaining brackets and removed the window. I was at first a bit confused as the sealer was in fact fine! So now what I thought. So I cleaned everything up then had a close look at the van and window unit. I finally discovered that the screw that holds the centre seal/upright bar in the window frame had started to rust and become loose and was letting the water slowly track in through the screw hole. As it was likely to snap if I tried to replace it, I simply covered it well with polyurethane sealer before refitting the unit. I have never had any trouble since and the walls are now nice and dry. You may be able to seal it in place but I took them out so I know it won't leak again. Hope this may help.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
thanks Nigel
does any know where the vehicle weight etc stats are written on a b694?
cheers
It depends on the age of the van. It should be under the bonnet (mine has the Mercedes factory plate) but for over ten years, Hymer have put a weight plate on the grey skirt towards the rear of the UK off-side. Mine is just in front of the rear wheel.
Turls
cornwall
hymer 564
3 years
Hello Nigel , I saw your post on leaking hymer window , mine is leaking in exactly the same spot and after careful examination I thought that my ally frame had hairline cracks in it , so I blocked up the drain holes and filled the the frame carefully with water to find it p##sed in . after seeing your post i'm almost convinced its the same screw hole leaking because of how quick it flowed in !! Good news for me I think !!
Do you think I can seal it up without taking out the window successfully ??? I am very reluctant to disturb the frame really ,
Many thanks Nick
43,329
49,441
Hi Nick and welcome.
Unfotunately this thread is 18 months old.
Best thing to do is open a new thread under the tech/mech section of the forum.
Click FORUMS at the top of any page and scroll to the tech section the start a new thread.
Oh, by the way.....bite the bullet and remove the whole frame, you dont know how much damge may have been done to the wooden batons and sealing it in may make it worse.
Nigel67
98
82
Hymer b544
since 2003
Many thanks Nick
Hi Nick, just to confirm my windows have not leaked since. It would be difficult to access the screw successfully as its at the bottom of the frame. It was not to difficult to remove the whole window, which I originally did as i thought the seal on the window itself was leaking. After I cleaned all the old sealer off the frame and opening I used Everbuild PU40 polyurethane sealer (like sikaflex) available from Trago mills or screwfix, under £4\tube. If your reasonably handy its a fairly straight forward job.
Turls
cornwall
hymer 564
3 years
Hi Nigel thanks for your reply , I can put the van in mate garage for a weekend soon ,so after your confidence boost I shall tackle taking out the window !!!!! thanks again Nick
