Wind generator for 12v battery (1 Viewer)
motorhome42
48
15
North Tyneside
Auto-Trail
Since 2009
I have no idea what the set up would be but what would I need to set up a wind generator in order to charge my 12v battery. I already have a solar panel to help charging.
Many thanks for any future replies.
DBK
18,019
48,071
Plympton, Devon
PVC, Murvi Morocco
I wouldn't bother unless you are just looking to have something to keep the batteries from going flat when the MH is parked up unused.
It's a simple matter of cross-sectional area and how much power you can extract from the wind. Would be pretty noisy too inside the MH.
In a Force 5 this will generate just 72W, and it will be going like the clappers while it does. OK if you only go to windy places. I'm certainly not anti-renewables, quite the opposite, but micro-turbines are really only useful in limited applications, of which yachts are one as they can travel faster through the air than the prevailing wind - and a bit of rattle and flap goes unnoticed on a yacht. Broken Link Removed
But don't let me talk you out of experimenting, give it a go and let us know how it goes!
Jim
Ringleader
Jul 19, 2007
36,392
130,704
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Dingray uses one. Most showgrounds are windy old airfields and I've seen it spinning away merrily all weekend, how much it generates though, I've no idea
GJH
29,450
38,827
None, now sold
2006 to 2022
Just one FUNster owns one but I don't think I've ever seen him use it.
Dingray praises his (Forgen 500). We've been camped next to him and suffered no noise problems. I would have one myself if they weren't so expensive.
Reactions: DBK
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I have a vertical axis wind generator and when in use find it a sterling bit of kit. It will not keep on top of battery charging on its own, but coupled with a solar array it works fine. It trickle charges when dark or if no sun 24/7. What I do find is during inclement weather when there is no sun there is often wind.
DBK
18,019
48,071
Plympton, Devon
PVC, Murvi Morocco
The Forgen 500 is 12W in a bit more than a Force 4, and the design is such it should be fairly quiet, compared to a fast spinning horizontal axis turbine. But even the manufacturer states they are only a trickle charger. Every watt helps of course but don't expect it to recharge flat batteries.
Lenny HB
53,404
149,851
On the coast in West Sussex
Hymer B678 DL
I looked at them a few years ago and decided Solar was the way to go. Unless you have a force 8 gale blowing you will get very little output. OK in theory, you will get output in the dark which solar can't do but in reality apart from extreme weather condition the wind normally drops at night. Very expensive for the obtainable output compared to solar.
GJH
29,450
38,827
None, now sold
2006 to 2022
No, it won't recharge flat batteries but neither will a solar panel. Ray's description of his experience is very similar to Dave's:
It's interesting to read Dave's description because the early reactions to that model (which used to be sold by Maplins at a far lower cost than the Forgen or the VAWT they sell now) were nowhere near as positive. I'm left wondering whether bad reviews were left deliberately.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
The problem being was that people were buying the Maplin wind generator as an alternative to solar panels as at that time solar panels were almost twice the price they are now. Since then solar has dropped dramatically in price. There is no substitute for solar when the sun is shining, BUT, as a back up the vertical axis wind generator will help on a cloudy day as long as there is some wind. It must also be remembered that not everyone has room on the roof for another solar panel. The other problem with the vertical axis charger is that it requires a good solid fixing, not just loosely thrown on the roof. You will also require some form of getting onto the roof to connect and disconnect the turbine for travel. In my opinion, if used correctly the wind charger is a good bit of kit, but that's only my opinion as it did take some time to sort out the correct fixing.
Reactions: GJH
GJH
29,450
38,827
None, now sold
2006 to 2022
Agreed Dave. VAWT would only ever be an adjunct to solar, not a replacement.
The roof access/fixing problem was the reason why I didn't buy one from Maplins at the time they were on sale as I would have had difficulty with the Autoquest we had at the time. Neither would be a problem with the Burstner we have now. Pity Maplins packed in selling them.
GJH
29,450
38,827
None, now sold
2006 to 2022
Don't wanna be argumentative, but my solar panels have charged my totally flat batteries many times :)
Yes, but the sun's brighter on Mars :LOL:
I suppose it depends how much oomph the panel arrangement has :)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
If it was a good option you'd see loads of them on aires - I don't recall ever seeing more than one.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I happen to have an unused/unfitted maplin model vertical axis wind genny sitting in my workshop. Any reasonable offers considered I think they originally cost ÂŁ150.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
May I ask why you never got round to fitting it Roger.
Abacist
3,726
10,647
Devon
N & B Arto 88F Tag
since 2013
I thought he said not to rely on a wind turbine to charge a flat battery?
C
Chockswahay
If you want something capable and quiet then you need one of these........
Broken Link Removed
However once you have seen the price you might change your mind :eek: let alone working out how to mount/demount each time you use it.
We had a (different make) wind generator on our yacht and it was fantastic in a good breeze, but noisy. The D400 is an excellent generator.......... but bangs per buck?? not for a motorhome I think:(
Lenny HB
53,404
149,851
Hymer B678 DL
Broken Link Removed
Still needs a force 6 which is quite a strong wind to produce 200w, on an average day you would struggle to charge your batteries, think I'll stick with solar.:)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Between one and four amps, Jim. One to two amps in a fair wind, peaking at four in a storm force wind. (y) (at least my Rutland 913 did).
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Fleabay
Broken Link Removed
Or one like Rogers :
Broken Link Removed
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Guy in La Manga 2007 had a big one running, Separate pole and guyed, not only noisy in his R-V, but the guy next door complained too!!.
Pete
C
Chockswahay
Unless you live in Scotland LOL ....... no use for solar either :rolleyes:
