Wild camping and the leisure battery....
Discussion in 'Wild Camping' started by mike9jr, Nov 13, 2013.
  1. mike9jr
    mike9jr Read Only Funster
    Nov 11, 2013
    42
    12
    Glasgow
    Hi,
    Newbie questions....
    Bessecar E410- Toilet and shower....
    I believe that if I'm not hooked up, ie, when wild camping, that the plug sockets in the van are pretty much redundant...?
    I assume I can cook with gas, heat with gas...ok.
    But, can I heat the water and use the shower while parked in some remote location for a couple of days?
    Any advice gratefully received.
    Mike
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,462
    7,744
    Yes... Almost every van has a gas water heater.. Remember to take off the outside vent cover or it will never light...
    Correct on the electrical sockets, you can fit an inverter BUT thats another subject, advise you read up here on the forum..
  3. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    Yes you can if gas heated. Your electrical supply is 12v from your battery so lighting and water pump and any 12v socket. Fridge needs to be on gas unless electric only (compressor).
  4. maz
    maz Funster
    Jan 26, 2011
    2,534
    2,170
    Out there somewhere
    240v sockets won't work off hook-up (unless you have an inverter) but 12v sockets can be used to charge up various equipment (eg laptop) provided you have 12v adapters for them. Use gas to heat water but shower will use 12v to run the water pump. Couple of days should be ok but power taken from battery will need to be replaced at some point - either by driving, hook-up or solar (if you have it). Have fun wildcamping! :Smile:
  5. mike9jr
    Nov 11, 2013
    42
    12
    Glasgow
    Thanks for the replies folks.
    All makes sense.
    So I guess I'm going to need some 12v adapters for mobile and laptop, but at least i'll be able to get a shower and smell nice :Smile:
    That brings me on to reverse polarity...... I'll search around on the forums first.
  6. keith
    keith Funster
    Aug 25, 2007
    3,280
    1,655
    Ecclefechan
    You may like to consider one of these for charging SMALL items like phones. Being an inverter (changes 12V to mains electric) it will use more of your battery, but simple to use.
  7. Herman ze German
    Herman ze German Read Only Funster
    Jul 23, 2014
    29
    75
    We have twin leisure batteries fitted that charge via intelligent split relay charger & we can last 5 days without recharging . But we love to wild camp & are not a fan of campsites , so we bought a small 2 stroke generator only £60.00 from Aldi and works a treat , just plug in our hook up cable & we have 240volt all round & recharges the batteries . We also have an inverter but that does drain the batteries a lot quicker !
    • Like Like x 1
  8. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    I bet that's quiet, .... the wildlife will run a mile........... and of course it will be Pure Sine Wave...... won't it?
    ;)(y)
    • Like Like x 2
  9. Herman ze German
    Jul 23, 2014
    29
    75
    Same noise level as a petrol lawn mower. .......Unless you have a grand to spare for a Honda eu20i !
  10. RS_rob
    RS_rob Funster
    Dec 14, 2013
    885
    605
    Turnford
    1st posted in Nov 2013 :whistle::whistle:
    • Like Like x 1
  11. Jim
    Jim Ringleader
    Jul 19, 2007
    26,128
    77,178
    Sutton on Sea
    A 2 sroke genny screams under even a moderate load, but as long as you are 'wild' and not disturbing others then the noise is immaterial. You wouldn't be too popular on a rally field though. :) I haven't used my genny in a long time. I'm a big fan of this Battery to Battery Charger
    • Like Like x 1
  12. scotjimland
    Jul 25, 2007
    28,934
    25,590
    indeed it will be.. can't get anything else from an AC genny.. frequency will vary with speed, but not the sine wave shape.
    it's actually purer than ' inverter technology ' .. which as the name suggests, uses electronics to convert DC to form an AC wave.
  13. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,057
    3,459
    walthamstow east london
  14. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,396
    2,445
    Tunbridge Wells
    If you want to wild camp a lot or use small CL/CS type 5 van sites then you will need to increase your battery capacity first. We have 2 x 110AH Banner batteries that will last us 4 days before recharging.
    Then decide how you will recharge when needed. I like a peaceful quiet site, and therefore for me using a genny is exactly opposite to what I want (and would give me a headache in no time). And, as Jim says, cheap two stroke ones make a lot of noise. Not fair in your neighbours I reckon, whether they are other people, or the wildlife you came to see.
    I went for solar - I fitted 2 x 100W panels with the necessary controller and wires for a lot less than it would cost to buy a decent genny. It then just works seamlessly and without any fuss. The only thing I have to do every so often is poke my head out of the roof window and give them both a clean.
    All my lights have been changed to LEDs, my TV is 12V and I have 12V chargers for most of my electrical stuff such as phone, tablet and shaver. For the occasional 240V needs (so far wife's hair dryer, toaster and electric bike chargers) I have fitted a 2000W inverter. Did not need to bother with an expensive pure sine wave one because none of those need it.
    However you will need to think more carefully about winter trips. The solar panels become a lot less effective and the biggest user of electrics will be the fan for the blown air heating. And the longer nights also mean that you will probably have lights and TV on more, although you could always go down to the pub to avoid that!
  15. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    Aldi currently have 12v sockets for around 4 quid. They have 3 female fag lighter type sockets plus 2 USB sockets. It just plugs into your 12v via a male fag lighter type plug.
    We've used one for charging our phones, Ipad etc. also for power to the TV & aerial for the last year or two now. Wouldn't be without it, in fact we've just bought one as a spare in case ours breaks!
    Also have solar & ctek dc to dc charger . Great so far(y)
  16. Peter_n_Margaret
    Peter_n_Margaret Read Only Funster
    Oct 27, 2013
    87
    62
    Adelaide, Australia
    We are touring Europe for 6 months each summer and only wild camp.
    The MH has a compressor fridge, 280Ah of batteries and 430W of solar. Even during poor weather, the solar produces some power.
    Recharge capacity is more important than battery storage, in my view.
    I would also recommend a decent DC-DC charger from the alternator, but we don't have one.
  17. tambo
    tambo Read Only Funster
    Jun 21, 2014
    875
    637
    Dunfermline fife scotland
    I don't think I've ever used the 240v in my van .....i only have the one leisure battery and always wild camp with exception to recent holiday in france
    The van is designed to be fully self sufficient but i guess it depends on how much equipment your running etc but I can easily do 3 or 4 days just running on my 12v battery and gas , i don't run any inverters either
    • Like Like x 1
