WIFI in Motorhome (1 Viewer)
Oct 14, 2007
3,958
6,134
Rochester
Auto-Trail Mohawk
16 fun filled years
I need to have a solution for picking up WiFi and setting up a hot spot in my MH, I know you can get Motorhome Iboost but being a poor southern lad I need to look for a cheaper option. Is anyone using the Solwise kit?
Solwise USB WiFi Router/Repeater with the Outdoor USB Directional Antenna with built in 12dBi antenna?
http://www.solwise.co.uk/wireless-usb-usbwifirpt-3000.html
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
I use a TP-LINK TL-MR3420 connected to iBoost Pro D8 and because it can allow the use of a sim dongle I have the best of both worlds. I also have a 4tb hard drive connected to router via one of the four lan ports, which allows me to watch movies or TV shows on any device connected to wifi. I can access my wifi up to 100 metres away from MH in line of sight.
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
Now I know nowt about these devices but the one linked above.. Is that just to amplify the signal from a nearby router ? Like one on a campsite ?
I have one of those Heuwie devices that works well but would really like something better ? An external Ariel perhaps ?
I know I asked this question before but confusion set in and I lost the plot .
Don Quixote
2,966
5,257
VW T6 Campervan
@Charlie I do not know the system the OP has shown, but basically it can be set up to repeat ( make stronger ) the signal from say the campsite wifi to your MH and then use it around / inside your MH. They work very well but can be a pain in the ass to setup as you need to access the internal menu on the device each time you park up looking for the campsite wifi. I have to say you need to the same with "motorhome wifi iBoost system" as well, but they are a lot easier to use.
Don Quixote
2,966
5,257
VW T6 Campervan
Dane, having just read the user manual for the link your posted, the system you have asked about is the same thing as I have fitted, but smaller. Looks very good to be honest.
Charlie
3,211
3,639
Im a newbie
John. I dont want to boost a campsites signal. What I would like is an external or internal ariel that boosts the 3G signal to the Heuwie device. This device obviously has its own internal ariel but it cant be very big. I wonder if an additional ariel would help.
That said it works quite well most of the time.
In France I found the WiFi signal on campsites extremely poor ! My Heuwie device was far better but I feel could be improved upon ?
Don Quixote
2,966
5,257
VW T6 Campervan
@Charlie I do not want to "steal" this thread, so if you start a thread with heading Huawei Device External Antenna I will look for new thread and advice ( if I can ). Before doing this please check that on the bottom or side of your Huawei device that there is one or two ports to connect external antenna too.
Diabalo
Oct 14, 2007
3,958
6,134
Rochester
Auto-Trail Mohawk
16 fun filled years
I have an aerial that plugs into my Heuwie dongle and it makes a big difference, on mine there is a small flap on the side of the dongle where the aerial plugs in, the plug on the aerial is very small. But the original post was to improve any WiFi signal strenght and broadcast them in the van.
Don Quixote
2,966
5,257
VW T6 Campervan
Dane, thats why I asked him to start another thread. The system you have asked about looks very close to the one motorhomewifi are selling. I have to admit had I not got my own system I would be strongly tempted to buy the one your asking about having just read the user manual and setup PDF's. If you go for it let me know how it goes and what you think.
Diabalo
Oct 14, 2007
3,958
6,134
Rochester
Auto-Trail Mohawk
16 fun filled years
Don, yes it looks good on paper but it's always nice to get feed back from someone using it. The 2 concerns I have is how to find the best signal, the only way I can see is to have a laptop plugged in on the initial setup when you rock up on site and is the interface going to be friendly? It's very similar to Iboost and at half the price worth considering.
Don Quixote
2,966
5,257
VW T6 Campervan
Dane I would have thought as it's close to or same as iBoost router any member on here can advise who owns one, however I know having used the iBoost system that the Wan port is connected to the iBoost Pro D8 and you access that interface via the web page menu. In the case of the solwise router ( looking at the manual ) it has a more complex menu but like most thing new will be easy to master after time.
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes I use that. It is also the first issue that Motorhomewifi released.
The only trouble I ever had was with the power supply which is only 9 volts on the cigar lighter plug.
I discarded the plug and connected direct to my habitation 12 volts. The unit is 12 volt rated so I cannot understand why the hell a 9 volt supply for it.
Mr Mousy
616
3,091
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
I have the set up you mention with an omnidirectional aerial - works perfectly and cost about £100.
Used it all over the UK and France to pick up FON and also any other open networks I could find.
Also handy if you buy a campsites wifi and it is limited to one or two devices.
You log onto the site wifi with the router and the re radiate the wifi using the router to as many devices you want.
Solwise also have great support if you have any problems.
No need to spend any more than £100 for a good set up.
@Diabalo
Don Quixote
2,966
5,257
VW T6 Campervan
Andy, I take it you are using the USB port to the external aerial. I wondered if it works with the Broken Link Removed connection version from motorhomewifi?
Diabalo
Oct 14, 2007
3,958
6,134
Rochester
Auto-Trail Mohawk
16 fun filled years
Don we are in the Netherlands at the moment setup has been working great in Fance and here very quick to set up and no problems.
JockandRita
11,402
148,466
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
I too use the ALFA R36 set up with either a good directional USB Egasky antenna which I can use internally, or an omnidirectional 8dbi external antenna connected to an ALFA Wireless adapter. Here at Stratford Racecourse, I was picking up 49 different router signals with the internal antenna alone. Unfortunately, BTresidential router signals are only good for a 10 metre range, and although I was getting a 73% signal strength, the nearest BT router was too far away to connect. Adam at Motorhomewifi did explain the reasoning for that. Apparently BT Business routers give out a greater signal.
On this occasion at Stratford, I've had to revert to my MiFi.
Cheers,
Jock.
Feb 13, 2013
984
1,057
Edinburgh
Rapido 881F
Since 2015
Just back form 3 months and used a combination of MiFi and wifi booster aerial. I use a linux Netbook which I have set up to create an internal wifi hotspot and it works a treat. I have been trying to minimize the amount of tech gadgets I cart about and having a combined device that I can use for email, web browsing and a router/hotspot is just the ticket. Plug in the booster aerial in the USB port run the scrip and voila we are all connected to what ever WiFi network I can find. (I don't use it for streaming although, I experimented when it was tipping down and did get a firestick to load!)
I am pretty sure that if you use Windows devices there will be commercial software (Connectify?) that also allows you to do this but I prefer Linux for traveling as it is FoC and the community support you get. ( Not knocking MS I also run Windows on a beast of machine in the house!)
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
I use the Solwise USB unit with an Ebay 16db directional aerial and it works great, you have to make sure the chipset in the aerial is compatible with the USB unit but otherwise great and costs a fraction of most other systems.
JockandRita
11,402
148,466
Lincs/Cambs border
N+B Flair 8000i
in tune with @maxi77, I found that the USB unit from Solwise wasn't compatable with the Ralink chipset in the Egasky antenna, so I sent it back. I then ordered the ALFA R36 unit fron a seller in Spain, which was compatable with the antenna chipset.
Cheers,
Jock. :)
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
Cheers,
Jock.
Hi Jock
As you know we are also at Stratford, I have been using my 3 12gb data card as it doesn't seem to be going down very fast but thought I would try my MotorhomeWiFi device as a comparison.
I am connected and posting on it now, data switched off.
Martin
JockandRita
11,402
148,466
Lincs/Cambs border
N+B Flair 8000i
Hi Jock
Martin
Good morning Martin (just). :)
I'm sure if I just stuck my antenna on the roof, I'd be fine, but I can't be bothered to remove the ladder guard and climb up. ;) I'm saving my 3 sim for when abroad, and currently using my T Mobile (EE) sim @ a fiver for 30 days internet. (y) Cheap as chips. :LOL:
Cheers,
Jock. :)
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
Cheers,
Jock. :)
You didn't want to be on the roof in that rain Jock:LOL: ours is just stuck to the window inside but we have a better line of sight to the flats than you have I guess.
Martin
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
im typing this post cos im happy to have got my super duper satalite internet all singing and dancing thingumy jig working ,message being sent miles from a wifi hotspot (y):D:D:D:D:D:D:D:D:D:D:D
Techno
Jul 28, 2010
15,475
20,752
May 2010
I do that from my phone and have 5gb a month for £20:p
