Why would gas stop working?
Discussion in 'The Beginner' started by Hollyberry, Apr 2, 2012.
  1. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,870
    7,630
    Paignton, Devon.
    Went away yesterday. gas working fine on arrival and this morning--made tea, used water heater.
    Switched off water heater.
    After lunch decided to make a cup of tea--no gas coming through to hob. Thought it was odd as gas cylinder only been used for 1 weekend and yesterday. However, the cylinder did seem light--wondered if I'd be sold a duff cylinder so swapped to 2nd (new one)
    No gas coming through to the hob at all. Even if I just turn on one burner, wait to see if it is air displacement, there is no sound of gas at all.
    I looked through all the manuals--no mention of any automatic, emergency switch off.
    I've not altered any of the knobs--they are all in open position.
    Shall I try the water heater ?
  2. alan
    alan Funster
    Aug 21, 2008
    536
    481
    skegness / spain
    Gas cooker
    Make sure the glass cooker lid is completely up or this sometimes cuts of the gas supply
    Alan
  3. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,870
    7,630
    Paignton, Devon.
    Yes, did that.
    Also thought of draft from door so closed that--there is no gas coming through at all, yet it worked OK this morning.
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,691
    5,845
    Mansfield,Notts
    Me suspects your regulater may have gorn up the spout:Sad:
  5. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,130
    13,880
    Heavan
    No gas at all?
    Sounds real simple,
    Or
    Regulator?
    however, normally with a duff reg, you get something somewhere and strange it just stopped?
  6. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,870
    7,630
    Paignton, Devon.
    Oh bu****. Only had this regulator put on about 3 weeks ago--but it wasn't a new one so maybe it's knackered. Would I be able to change it if I bought a new one tomorrow?
  7. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,517
    Tyne & Wear, sometimes..
    In your gas locker where the bottles and regulator are, (follow the hose from your bottle), do you have a little push button under the regulator?
    Mine is yellow, I think, it's on the underside.
    I have to push mine in (upwards) to reset it before the gas will flow again, if the gas has been turned off at the bottle or gas has run out, or the bottle disconnected/changed.
    • Like Like x 1
  8. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Gas bottle empty...........or regulator
    The newer truma regulators are not too impressive......seems the get oil inside them from the gas bottles then pack up.......the older ones went on forever....thats progress !
    barry
  9. Hollyberry
    Hollyberry Funster
    Apr 24, 2011
    3,870
    7,630
    Paignton, Devon.
    Thanks--but can't find any button. :Sad:
    Heater and water heater won't work either so I'm hoping it is just a duff regulator --I didn't realise they could stop working (but then I don't really know what they do)
    I'll buy another tomorrow.
    Was having such a nice time at La Jamaye too. I was the only person there last night and til about 10 this morning & dogs were having a great time chasing lizards.
    • Like Like x 1
  10. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    when you fit new regulator make sure it is above the level of the bottles or at least the pigtail drops down to the bottles, that way any sludge in the gas will not GUM up the regulator. common fault with intermitant gas flow.:Eeek:
    • Like Like x 1
  11. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,366
    9,811
    Its only a 5 minute job to change a regulator, but you need to get the correct one. They come in 10mm (more common) and 8mm output.
    once youve got the correct regulator
    turn off cylinder/s and disconnect the high pressure side of the regulator (at the other end of flexi pipe from bottle/s
    unscrew the outlet nut (it wont come off yet)
    undo the screws holing regulator bracket to the wall
    lift off faulty regulator from pipe
    reinstall new regulator in reverse order and check you get the connectors tight
    after installation get some washing up liquid in a cup with water to dilute
    turn on cylinder/s and paint the washing up liquid around joints
    CHECK FOR BUBBLES, which mean you have a leak
    tighten and retest if neccessary
    when your happy its all done, go indoors and light the gas hob etc to proove its all ok. will take a while to light as you need to purge air from the pipes, just keep the knob turned on and pushed in until gas comes through
    sit back and enjoy a beer or a cuppa:thumb:
    forgot to say if you fit another truma regulator you will need to hold the button in on the regulator to purge the air from that too. Oh and be prepared to replace again and again until you buy one from cleese etc
    • Like Like x 2
  12. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,476
    1,325
    SW Northumberland
    Buy a compatible Gaslow Regulator, far superior product and has a 5 year warranty :thumb: we did after our almost new Truma reg died. Slightly more expensive but what price reliability and peace of mind?
  13. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    no gas
    Are you using Butane because its been cold enough for it to stop vapourising - the result is no gas until it warms up again.
  14. Technophobe
    Technophobe Read Only Funster
    Apr 19, 2012
    4
    West Yorkshire
    That's what I thought, but on my last van, the (Truma) regulator was well above the bottles - but it still packed in. On a Bank Holiday as well - fortunately the site knew of a repairer who was available and sorted me out (well, sorted the regulator out - I'm well beyond sorting out :Doh:)
    Jon
  15. jaygee
    jaygee Funster
    Mar 21, 2009
    1,168
    721
    Harwich, Essex
    Simple things first
    Check you have gas in cylinder,use pressure gauge if you have but i guess you havent
    Remove cyl and just crack open valve,you will soon know if you have gas or not
    If not chances are its been leaking from time of replacment,i now always check joint when replacing cyl
    If you have gas then work your way back through system:thumb:
  16. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,583
    22,482
    Narrfoook
    And just to confuse the issue a little...........
    We have Alugas system fitted
    There is a valve in the pigtail... Mine jammed completely shut !!
    I replaced the truma regulator knowing how duff the new ones are ( with a gaslow one just as Stewart says ) only to find I STILL had no gas.. It was only then I discovered the pigtail was completely blocked by the bloody valve
    There was an up side.. I no longer have to worry about the Truma giving up the ghost at an inconvenient moment !
  17. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,761
    39,072
    Just as a precaution and a safety issue.... I would get your gas line preasure tested...
    Just in case a joint is leaking.. As you thought it was a newish bottle or only been used one weekend.. :thumb:
  18. Jaws
    Sep 26, 2008
    18,583
    22,482
    Narrfoook
    Or you used blown air and its a 6k bottle !! Mine empties one of those in a day !!!
  19. Big Deefer
    Big Deefer Read Only Funster
    Oct 27, 2011
    6
    Derby
    truma?
    My very first trip out involved no gas coming thru... quick trip to spares shop supplied me with 1 proper calor propane reg, 1m of pipe and 2 jubilee clips. problem solved.apparently Truma regs are not up to much reliabiity wise..
  20. boleyngirl
    boleyngirl Read Only Funster
    Jun 3, 2012
    Southampton
    Thank you soooo much!!
    You have just saved us a lot of money buying a new regulator. We bought new gas bottle, put it on and just a trickle of gas. We came home from campsite as no electric hookup available. I went onto this website from Google and read your answer re yellow button and yes!!! We have a yellow button, so the button wouldn't press in so we took it off and pushed a little rod into the hole and as if by magic we have a full working gas cooker again. Thank you so so much!!!
    • Like Like x 1
