Why does my Surflow pump keep going? (1 Viewer)
Mar 21, 2010
2,486
2,992
Why does my Surflow pump keep making a noise, when both taps are off? The only way I can stop it is by switching off at the main control. .
colyboy
scotjimland
2,301
9,952
A Woosh bang
you have a leak somewhere on the pipework, at a tap.. or pipe union..
ran out of water.. tank empty
or the pressure switch on the pump is u/s .. or needs adjusting
Feb 9, 2008
8,945
18,698
Corby, Northants
Coach Built
All of above is spot on ! I just thought I would add that if your boiler drain valve is open the pump will continue to operate in order to fill it.
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Mine also runs continously occasionally no leaks or valves open in does sound different when it does this usually clears when i switch off then on again
ukbill
5,501
5,274
Pinoso
4 berth low profile
starting on saturday 10/3/2012
happened to me while touring,found it was the shower control just slightly open
funflair
19,330
30,167
Guisborough
MORELO palace
since 2012
If you can't find a slight leak after the pump it could be the non return valves in the pump itself so might be worth stripping it down, cleaning and re building.
Martin
colyboy
Mar 21, 2010
2,486
2,992
Once again thanks to all MF members who have come to the rescue. All sorted now.
colyboy
madgeD
259
480
Cleveland
Van conversion
since 2005
Every caravan and van we have had has occasionally pressured up in fact we were told that it would happen from time to time.
TerryL
6,176
8,177
North East
Low Profile
Probably a bit of detritus in the pressure valve, stripping and cleaning cleared it out.
