why do manufactures use powder paint for exterior fittings (1 Viewer)
mentaliss
654
306
Lancing
C class
In this case, twin rear view camera's where the paint has peeled off in under three years... we live right on the south coast and anything we put outside e.g. lights etc that are powered coated will be minus of there paint coating within three years...powder coat paint was devise for interior items like Hifi amps etc etc
tonka
10,823
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
Cheap and quick I guess..
My business was satellite TV, most dishes were just steel and powder coated, they didn't last long near the coast. Soon went rusty and looked a mess.. However we had a nice sideline in upgrading to Aluminium dishes :) so that was a plus for me..
zac
2,597
1,848
Basingstoke
Rapido A CLass 10000
since 2013
Had exactly the same issue, camera fitted November and come March it had rusted, i did get it replaced by the same company that fitted it so that was one thing but for something that will always be on the outside you would of thought they would of used something a bit more resistant
DuxDeluxe
14,652
72,592
Planet Zog
A woosh bang van
since 2008
It's relatively cheap to do......
......mine started rusting after a year (Waeco) so I removed it and painted with hammerite.
zac
2,597
1,848
Basingstoke
since 2013
I would of done the same if it had not been under warranty, i will be doing exactly that when this one starts to rust though. :)
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
When I have exterior stuff Powder coated I spec minimal zinc coating base but prefer galvanise, thin sheet metal will distort with galvanising though.
Lenny HB
53,304
149,475
On the coast in West Sussex
Hymer B678 DL
Every towbar I've had on a car has had the same problem, powder coating is fine until it gets a pinhole or chip in it then moisture gets under the coating and it just flakes off.
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I'm using a mini CCTV camera: cast aluminium, powder coated, stainless fasteners and a concealed cable entry into the van. Oh and a shaped stainless plate underneath glued to the van to cover the four holes Brownhills drilled fitting a camera for the previous owner.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
It works best with an etch primer sprayed on first the it will adhere to pot metal, I can powder coat items that will then last, the reason they use it is that it takes no skill to do and goes through the factory with out waiting for paint to dry. Save time and skilled labour, it also clings to nearly all the surfaces uniformly, however it is only a plastic film and the slightest crack allow moisture under it and filiform corrosion takes place, creeping along the surface and pushing the coating off,, just look at old aluminium garden furniture and it will lift off in lumps leaving the powdered oxide as a lousy surface to try and paint over to make it better again
Nov 23, 2011
479
405
durham
Lowline
since 2006
Powder coating is normally very durable. Its the substrate its painted on that is the problem. it should either be zinc phosphate or galvanised steel and coated with a self etch primer for outdoor use. They just probably powder coat over mild steel. It looks good but will only last a short time.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I forgot to mention that when I powder coat I normally bead blast the item first then use a solvent, then self etch then powder coat it. Most commercial items are blown straight on and baked, over the rust, scale and weld oxides. These flake offand the coating flakes off with them. once it has broken the plastic skin, water is in and the whole thing goes manky very fast.
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
Since 2010
My camera mounting bracket is also flaking.
Less than 12mths old.
Just the action of tightening a screw up can break the coating
DuxDeluxe
14,652
72,592
Planet Zog
A woosh bang van
since 2008
Yep - surface preparation is everything.
