Why 2 battery chargers.
Discussion in 'Tech/Mech General' started by Snowbird, Jun 1, 2014.
  1. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,169
    16,610
    Liverpool.
    Just been in the RMB power station and what do I find in there...two battery chargers.
    One is a Calira Sealine Ladeautomat LG627-DS/IU
    The other a Calira Elektroversorgung EVS 30/30 DS/IU
    They both seem factory fitted and are all wired in, so what would be the idea behind that ?.
  2. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,040
    3,420
    walthamstow east london
    leisure and vehicle seperately? or could it be one is a charger and one a power supply unit
    • Like Like x 1
  3. Wobby
    Wobby Read Only Funster
    Aug 26, 2007
    83
    55
    Hailsham
    On our first new van we specified an extra battery and with it came an extra charger, perhaps it for fast charging but not sure.
    Wobby
    • Like Like x 1
  4. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    Quicker charging I guess. My Schaudt Electrobloc has the facility to plug in an auxiliary charging unit to give another 18A of charging
    • Like Like x 1
  5. Snowbird
    Apr 24, 2009
    10,169
    16,610
    Liverpool.
    The chassis batteries are 24 volt and the habitation batteries are 12 volt. Its a possibility thats the reason for the two, but I have never come across this before.
  6. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    I suppose they may be wired into 24 battery in series, with a separate take off on one i=of them for the 12V? Sounds a bit of a clumsy way to do it though.
    • Like Like x 1
  7. Snowbird
    Apr 24, 2009
    10,169
    16,610
    Liverpool.
    I agree, it is a strange way of doing it, but why would they use two different models of charger.
  8. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    If its anything like Schaudt the main one does the charging and distribution of 12V to various circuits whereas the other one is just an auxiliary charger that plugs into the main one and is controlled by it. Both the same makes so I suspect that may be the same with yours.
    Found and this for you
    • Like Like x 1
  9. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    And this as well
    • Like Like x 1
  10. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    Bugger
    Try this then
    • Like Like x 1
  11. Snowbird
    Apr 24, 2009
    10,169
    16,610
    Liverpool.
    That seems feasible as they are plugged into each other :thumb:. Am off to the hospital now for another small op. When I return I will take a photo and post it. Hopefully this will confirm your suspicions. Many thanks for the input :thumb:.
  12. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,439
    Tunbridge Wells
    Good luck with the op.
    Makes sense because one of them has a female kettle lead connector, which suggests that it was outputting a charge
