Whos been using my Toilet? (1 Viewer)
jumar
3,693
11,211
Spain
Hymer Tramp
Since 1994
Hi funsters, woke this morning visited the loo, as you do, the bowl is filling, not by my doing but with the flush running.
The pump is off, but a steady drip is filling the bowl.
A syphoning is possibly happening?
Anyone has this happen to them, quick replies please, I'm busting now.
jumar
jumar
3,693
11,211
Spain
Hymer Tramp
Since 1994
Directly fed from main water tank.
Nov 4, 2011
5,886
38,109
Uk
We had this problem when we had a caravan, that was down to previous owner not fitting a anti syphon valve, I fitted new one, problem solved.
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
If it's fed directly from the main water tank it will be using the main water pump. Is yours a pressurised system or microswitches on the taps, if it is pressurised the toilet has a solenoid valve to open and let the water through to flush it sounds like the valve is leaking.
If you are worried about it overflowing switch off the pump overnight.
Martin
Candapack
711
2,639
Fife, Scotland
Since 2013
I suspect you've been the victim of an overnight gas attack, with the miscreants using your loo during their evil doings. Check your personal belongings. :LOL:
jumar
jumar
3,693
11,211
Spain
Hymer Tramp
Since 1994
:LOL:My personal belongings are untouched.
And more inkeeping with the initial posting my drip has stopped for now.
I will monitor the fault and replace if required the valve.
(Martin) Turning off the pump didnt change anything, it seems to be syphoning.
Reactions: DBK
funflair
19,199
29,887
Guisborough
MORELO palace
since 2012
To syphon the exit would need to be below the tank water level as you can't syphon up hill. If switching the pump off is going to help you would have to open a tap to release any pressure.
Otherwise I can't help, Sorry.
Martin
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
Place some tissue around the water outlet and see if it gets wet. You may need to strip it down and check behind outlet to see if loose or cracked or may just need to tighten.
