Which weight? (1 Viewer)
Sep 24, 2013
1,307
739
Norwich
Carthago A class
Since 2014
The plate in my new Ducato engine bay shows gross weight of 3650kg, but the Burster plate inside the MH says 3500kg. Which one will any authority take. Chassis manufacturer or coach builder?
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
What revenue weight figure does it state in the V5C?
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
since 2007, 25 years tuggin before that.
The weight on the V5 is the legal max, if that is 3500kg it would be a paper exercise to up plate to 3650kg.
kelv
672
894
leicester
Carthago 145
check the v5 it sounds like it has been up plated already .when you up rate the weight they send you a new plate to put along side the old one.
stevec
Sep 24, 2013
1,307
739
Norwich
Carthago A class
Since 2014
The MH is only 3 months old and has the original engine plate as fitted by Fiat. The revenue weight on the VI is 3500kg. Presumably any authority stopping me on the side of the road will have access to DVLA records or will they just look at a vehicle plate?
Jul 27, 2010
704
1,452
Farnham Surrey
Bilbos Nexa
on and off since 1980
P
Probably downrated by Burstner for licence purposes
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
I do not know why MH assemblers downrate to 3500 kg but in your case it is straightforward to have your V5C amended to 3650kg if you need to do that. It puts the vehicle in a different tax class which is cheaper but there will be some implications which might include additional insurance, breakdown recovery costs.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
As others have said, it has been down-rated to 3,500 kg by Burstner in order to appeal to non C1 licence-holders (or the equivalent abroad if it is an import). That will be the recorded revenue weight and will be available on-line to any inspecting authority.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Why do they do this and count you as a COMMERCIAL VEHICLE. it is all down to making them something they are not. I got caught as a LORRY going into the LEZ, and the fine is £1000 if imposed. A normal transit (same vehicle at 3500kgs ) is allowed no problem Because it was Euro3. Why cannot the authorities put them down as private leisure vehicle and that would stop the farce of driving licences needing to be same a a commercial lorry driver, C for new drivers with all the palaver that entails, and the medical problems for the older drivers at 70 all for a few kilos to make them legal with a small amount of private goods and shekels on board. After all the weight difference is only the weight of a couple of OBESE people and there spare clothes.
Minxy
32,624
66,461
E Yorks
Carthago Compactline
The 'legal' plate is the Burstner one, so 3500kg max. You may be able to get it changed by DVLA to 3650kg if you can get something from Burstner to say it is still okay at that weight - if you've got the Certificate of Conformity check what that says. If Burstner won't play ball then the only way AFAIK is to get an engineer to approve it to be uprated as it is - SVTech is the 'usual' people to do this but I used another chap myself who was about a fifth of the cost!
Many mainland Europe produced MHs are kept at, or reduced to, 3500kg weight due to licencing limitations for buyers in their own country.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Put it on a weighbridge, now! A couple of years ago we had a Burstner in for air assist rear suspension but after a weighbridge visit (prior to fitting the air assist) it became obvious that the vehicle was simply not fit for purpose. Although it was plated and registeerd as 3500KGs GVW it was almost on that empty, even the driver would put it over its maximum weight!
D.
Zigisla
2,576
3,101
Gosport, Hants
Sunlight A72
Getting better month by month.
Almost irrelevant it may seem. My V5C arrived with a revenue figure of 4000Kg on it. No where near I thinks to myself. Bearing in mind this is a brand new MH and all paperwork was sent to DVLA at the same time. Certificate of Conformity says it weighs 3850Kg. So who is right I thinks. Manufacturer plate or DVLA log book...
Today, arrives another V5C with revenue weight 3850Kg. How on earth do they get things so wrong and when did they realise. The Mass in Service weight has gone up as well.. - what ever that is.
Cannot guarantee the V5C is going to be correct. xroll:
Diamondcub
52
29
Basingstoke, Hampshire
4 years
D.
Dave, that is exactly what I found on my Burstner Aviano, over weight prior to loading. What did you do about it?
Aug 18, 2014
23,742
133,210
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
@dave newell lvs , I'd be interested as well ?
I tried not to laugh but you are totally correct . Some of it is nonsensical. I have an acquaintance who has 2 early 90's Land Rovers. One , a swb pick up & the other a swb safari(?) one. They were built on the same day & are 3 numbers apart on the chassis number & with same engine.
One was classed as LEZ compliant form the outset & the other not. :(It is ludicrous.:xsad:
Jan 28, 2008
10,113
18,366
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
my son and his friend have two vws that apear identical one is compliant one isnt
Badknee
7,407
412,090
notloB
Vantage Neo
Living the dream.
When I bought our MoHo (53 plate Autocruise Wentworth ) I took it over the weighbridge with half full fuel and fresh water tanks, spare wheel and me. 3250kgs :xeek: So at 3500kgs I had 250kgs to go! It was just never going to happen in this world.
When I got home I looked at the V5 and was very pleasantly surprised to see it had already been uprated to 3850kgs and air suspension fitted.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Personally I did absolutely nothing other than advise the owner of the issues. I believe they rejected the vehicle as unfit for purpose (although I may be mistaken) and bought one that was usable at its quoted weight..
D.
43,304
49,293
How very true.
I used to have a Suzuki SJ410.
Unladen weight.....970kg...mine was even less, drivers seat only and every bit of unneccesary bodywork removed.
Gross weight.......3500kg
No way on gods earth could that little 4 x 4 have a payload of 2530kg....especially with a 1 liter 4 cylinder petrol engine.
Augusta08
961
1,422
Morbihan
Autocruise Augusta
Since 2001
Interesting posting... I've just checked mine the ALKO plate states GVW 4500Kg but the V5 is blank? I am classed a PLG and only pay PLG RFL rates. The Fiat plate states 4250 (in engine compartment) so I'm unsure what my status is.
Diamondcub
52
29
4 years
Hi MinnxyGirl
Thanks for your input, very informative.
Do you remember who you used please?
43,304
49,293
Your van is wrongly registered as 3500kg or less.
At 4500kg you should be paying private heavy goods rate of rfl.. £165 pa.
Technically, You may well be overloaded before you put anything in
Need sorting with DVSA
Minxy
32,624
66,461
E Yorks
Hi MinnxyGirl
Info below of the chap we used to do our uprating exercise (only cost us £76 but I think it's more now and depends on the amount of work that is involved). Best to ring and talk to him about what you want first. He's a qualified engineer but is an oldish chap so you have to be patient and wait for him to do the necessary (probably no longer than SV-Tech though!), his contact details are:
Mr AHJ Ruffles (calls himself John)
company is: JR Consultancy
tel: 01359 250808 / 01244 544 598
Email: johnatjrcon@aol.com
This is the email I sent him:
Further to my husband's (Chris) conversation with you today below are details of our camper which we wish to uprate from it's current MAM of 3500kg to 4250kg which we believe the vehicle in its current form is capable of being changed to without modification (the converter's COC shows that the weights are unchanged from the original vehicle supplied to them):
  • Reg No: FX15 RRZ (registered 7 May 2015)
  • VIN No: ZFA2500000*******
  • Vehicle: Fiat Ducato X250 Maxi 150 XLWB
  • Model Name: Globecar FamilyScout L (part of the Dethleffs group)
The weights shown on both the Fiat and Dethleffs (converter) VINs are:
  • MTPLM: 3500kg (to uprate to 4250kg)
  • Train: 6500kg (no change required)
  • Front Axle: 2100kg (no change required)
  • Rear Axle: 2400kg (no change required)
I attach the following information in a Word document:
  1. Copy of V5C
  2. Dethleffs (Globecar) Certificate of Conformity
  3. Photos of Fiat and Dethleffs VIN Plates & Photo of camper (showing registration number)
  4. Photos of Base Vehicle ID Logos and Tyre details
Please let me know if you need any more information. I look forward to hearing from you and hope you can help us!
Kind regards
Minxy
32,624
66,461
E Yorks
From what you've said I assume you have a Maxi heavy chassis with an Alko rear end.
The original Maxi heavy chassis would have been plated at 4250kg by Fiat
Then when it was converted and the Alko chassis added the GVW was uprated by the converter to 4500kg
IMV you therefore have a MH that has a GVW of 4500kg and should be in the PHGV class and pay only £165 a year, the fact that your V5C hasn't got a weight on it is just an 'error' on the DVLA's part so you need to get in touch with them but first I'd sort out the road tax first - get in touch with the DVLA and inform them of your being in the wrong tax class - you might have to complete the 'amendment' section on your existing V5C and send it in with a covering letter and ask for a refund of your over-payment from whenever you can get it backdated to, you'll also need to ask for a new V5C to be issued which shows both your GVW and Revenue weight at 4500kg (2 different entries on the form).
https://www.gov.uk/contact-the-dvla
Augusta08
961
1,422
Morbihan
Autocruise Augusta
Since 2001
Thanks Minxy and Papa, I'll get on to them next time I'm back in the UK.
(From Wet and windy Morbihan)
Minxy
32,624
66,461
E Yorks
