funflair
Alde wet system for us with the engine heat exchanger for travelling but our only comparison is the Caravan we had with blown air and a convector fire.
Ahh, but I wasn't suggesting the installation of refillable cylinders or a bulk tank Jon, ie,Factor in the cost of refillable bottles or fixed tank over an already-present diesel tank and the gap narrows considerably!
.............if on refillable gas, I'd possibly opt for the Truma E.
Thank you everyone, for your replies which were helpful and very informative. I am very grateful to you all.
Do you change your own burner assy.? I too have a Webasto DualTop (faultless after 3.1/2 years) and have never had it serviced. I would be interested in pictures for idiots if this is something you undertake your self.Further to my last post, the reason I emailed Webasto was to enquire how long an extension could be ftted to my heater combustion intake.
Our Dualtop lies in the firing line of water spray and dust from the left front wheel. I have developed a theory that spray and dust was being sucked into the burner, accelerating burner clogging and carbon build up.
Well, tonight when I got home, I removed the intake silencer and short intake hose. It was full of dirt!!!!!
This explains our high burner servicing frequency! I have ordered 2 metres (the maximum allowable length) of 22mm silicon hose and I will relocate the intake out of harms way.
This should extend servicing intervals! The Dualtops are all mounted externally in differing positions. If you suspect dirt is being drawn in whilst on the road, this is a very cheap and effective modification.
I will update you in two years time!!!!
Yes indeed, this is the season for heaters!It won't stop there!
We'll keep arguing about heaters now for months to come!!!!!
Good! A friend has an Eberspacher on a 2006 van & it is the stop / start variety. It can be pretty heavy on the 12v supply as it switches on & off - due obviously to the heater in the combustion chamber. Nice to know they've improved.They USED to!
The latest generation are better controlled and simply tick over at a low heat output rather than stopping and starting.
If you check the technical specifications you will find there is little difference between a Webasto Dualtop and Truma Combi in respect of their 12v useage.
We are quite happy with the performance of our Dualtop in the Alpine winter without EHU.
We certainly don't have to recharge our batteries any more frequently than anyone else on the aire.
Since most motorhomes carry crap leisure batteries anyway, its easy to blame the heater. Those who complain about their diesel heater would probably say the same about a Truma Combi if they had one!
If we do get to suffer electrical "black outs" here in Britain this winter, the 2 x Trumatic gas heaters will come into their own even more.
Cheers,
Jock.
Thank you! I'm sure other member's too will appreciate this, especially if it's in H.D. with subtitles LOL.I am changing the burner on Saturday in preparation for a workout in the Alps this winter!
I did consider a YouTube video or pictures. You have put me on the spot now!!!!
As mentioned earlier, our burner clogging is very frequent. The heater location in retrospect, is crap and leads to the heater ingesting..... Crap!!!!!
Moving the intake will help considerably I reckon.
Stand by for a Jon and Shell video production!!!!!
Our PVC has a Webasto dual top but it is mounted internally, at the bottom of the wardrobe under a removable cover. The disadvantage of this we found on our recent trip to Spain - it made the bottom of the wardrobe warm and heated up the beer and sherry we were storing above it when we were travelling. Not ideal. This wasn't a problem when we stopped as the booze was put in the front footwells either side of the dog but it was when moving during the day.
So we turned it off, the heater that is, not the dog, (haven't found that off switch yet) after breakfast which was hardly a problem as the weather was warm and the hot water stayed warm enough to do any washing up at lunch and the diesel heater re-heated the water very quickly in the evening.
We haven't had any problems with our Webasto but a not uncommon problem I have heard of is clogging of the drain valve due to hard water. A 5% solution of citric acid used once a year seems to do the trick. Webasto have published instructions on how to do this but I can't find my copy at the moment.
Edit, belay the above, found the instructions:
Thank you for this information. Can you confirm it has come directly from Webasto as I note it is not written on an official Webasto headed paper. Also, my operating manual states' Use wine vinegar for descaling the water heater, this being introduced into the appliance via the water supply. Allow the product to react and then thoroughly flush out the appliance with plenty of fresh water'. It's a bit vague as it does not state for how long it should be left to do it's job and no mention of heating ? Perhaps your information is more up-to-date, as mine is 3.1/2 years old. I do think 24hrs at 70 deg does not sound right but then again have no experience or knowledge of using Citric Acid.Yes indeed, this is the season for heaters!
