Which towbar ?
Discussion in 'Motorhome Chat' started by ShiftZZ, Sep 25, 2012.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    I am considering adding a towbar to the Rapido (Fiat base).
    There are several types.
    Flangeball Towbar
    Swan Neck Towbar
    etc
    What is the best one, I am thinking of adding a bike rack (electric bikes, I think are too heavy for the normal bile rack).
    Any suggestions?
    What would be the approx cost of fitting?
  2. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Cant help on the model dave
    but do I feel an A frame in the wind ??:)
    barry
    • Like Like x 1
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,740
    5,967
    Mansfield,Notts
    Without a doubt go "conventional" and you will find racks to suite your every need
    Go swan neck or removable and you will be stumped
    as for cost ,they vary depending on make and model of motor home and chassis type
    circa £300- £700 all in
    Geo
    • Like Like x 1
  4. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,714
    1,317
    living the dream.
    We have two electric bikes on our bike rack with the batteries taken out, each weighs 22 kilo and the weight limit on the rack is 60 kilo we are well within the range.
    • Like Like x 1
  5. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    No they are not. Especially as you remove the battery in transit.
    • Like Like x 1
  6. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    I'm just designing and then building my own towbar to fit my Ducato base....
  7. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    Where do you begin ?
    I've looked under mine and there is nothing substantial for about a metre then the FIAT chassis.
    How to you work out the stresses on something like that ?
    Failure does not bare thinking about.
    • Like Like x 1
  8. scotjimland
    Jul 25, 2007
    28,934
    25,604
    all tow bars had to be type approved .. can you have that done ?
    EDIT
    just noticed it doesn't apply to motor caravans
    In replay to the Dave's question.. agree with Geo ..
    get a flange tow hitch, the swan neck looks pretty but makes it difficult to add a bike carrier
    • Like Like x 1
  9. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,810
    39,344
    Get some "Roller Skates"..... Dave....
    A lot Cheaper and easier to stow.... :Cool::thumb:
    • Like Like x 1
  10. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,942
    I can just see it now. New for ITV Saturday, The Torvill & Dave Show :Rofl1::Rofl1:
    • Like Like x 1
  11. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Esentially I found a van the same as mine with a towbar fitted profesionally.....took a load of photos and some measurements......simples...It was on the same ALCO extension as mine....doddle...
  12. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    one piece of advise i will give is to make sure that the towbar does not hang too low under the van as this can make for problems.
    the one i had fitted to mine hung down where the ball flange bolted to the crossbar although it was only around 3 inches it did ground out on several occasions so after removing the assembly and having it altered so it is level with the rear chassis its not a problem.
    if you have a substantial overhang the risk of grounding is increased quite a lot due to the leverage.
  13. 1_man_and_his_dob(lo)
    1_man_and_his_dob(lo) Funster
    Feb 4, 2010
    2,266
    1,524
    Mid. Glamorgan, S. Wales
    Come on....we're not that stupid. First the towbar...
    ...then the trailer...
    ...and finally
    [​IMG]
    • Like Like x 2
  14. hilldweller
    Dec 5, 2008
    27,288
    26,279
    Macclesfield
    A cunning plan.
  15. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,957
    2,755
    Englishman in Mid Wales
    You both look as if you have been driving them for years:Wink::thumb:
    oh and my van has a Towtal fitted with a nice strong bumper as well, I can vouch for how strong it is as I reversed into a brick wall with it, not hard but hard enough to have damaged a normal bumper so it saved me some money without a dought:thumb: and if your van has a looonnng overhang as someone has said, then this will save your skirt as I have done that to a hire van as well :Blush:
  16. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,632
    YO11 2BD
    certainly is Derek.
    i made my own for an alko chassis ducato.
    hardest part was measuring for the holes in the side plates to match the alko chassis mounting holes while maintaining the correct towbar position....never drill holes in an alko chassis for any purpose.
  17. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,576
    10,004
    towbars for alko chassis are one of the only models available off the shelf. others have to be designed on a per model basis which makes them more expensive
  18. pappajohn
    Aug 26, 2007
    29,952
    17,632
    YO11 2BD
    Not for a DIY one.....from memory mine cost around £40 for the 60mm box section (3mm wall thickness) and 2 x 10mm mounting plates, £20 for professional welding (my welding skills just aint good enough :Sad:) a handfull of M12 bolts/nuts and a tin of paint....already had a new flange ball.
    plus around 8 hrs of my time designing it and cutting the steel to size
    around £70 for complete tow bar :thumb:
    • Like Like x 1
  19. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,907
    3,902
    Corby, Northants
