Which solar panel kit
Discussion in 'Motorhome Accessories' started by injebreck99, Mar 21, 2014.
  1. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,261
    1,353
    norfolk
    I an finally going to get around to having a solar panel fitted on the M/H prior to our tour to Scotland later on, I see that there are several on Fleabay, any recommended panels or sellers, and just as importantly, anyone had bad experiences with sellers or panels. I suppose something like a 100W Bosch might be OK, what do I need to look for in a controller please.
  2. Trikeman
    Trikeman Read Only Funster
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
    Sunstore - excellent kit. MPPT controller - no contest.
    Regards,
    Trikeman. :Wink:
    • Like it Like it x 2
  3. Tmesis
    Tmesis Read Only Funster
    Mar 28, 2013
    29
    10
    Surrey
    You won't go wrong with a monocrystaline Bosch. For the controller, if you can get an MPPT as these are far superior in efficiency than a simple limiter.
    You can get dual output controllers, but if you have nothing heavy drawing on the starter battery, you won't get much benefit from the extra output.
    Keep the cable between the controller and the battery as short as possible and a reasonable gauge. No need to go over the top as 100w will at most give 9 amps of charge.
    Mount the panels to give an inch or so of free air underneath them as their efficiency drops the hotter they get.
    (is there some irony in fitting solar before visiting Scotland :))
    • Like it Like it x 1
  4. Trikeman
    Aug 22, 2012
    1,525
    2,756
    North Somerrzet.
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,221
    15,204
    Leeds the one up North
    Avoid ebay seller Ecoworthy ! I'm still in resolution over their crap.
  6. themogs
    themogs Funster
    Oct 23, 2012
    863
    908
    Wales
    [HI]
    [/HI]
    We'll go along with what Trikeman says... Sunstore are pretty good:thumb:
  7. Techno
    Jul 28, 2010
    14,221
    15,204
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,928
    YO11 2BD
    in your dreams maybe. :Laughing:
    In theory it will produce 8.33amps....in reality it will produce 7amps in good overhead sun.
  9. Techno
    Jul 28, 2010
    14,221
    15,204
    6 amps is about optimum
    I have witnessed 18 amps from my 300 with mppt and that is more than the panels projected/claimed output
  10. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    It depends how much roof space you've got. If you've got plenty, just get cheap panels and controllers. You get more output from just buying more capacity than buying better quality. However, if you've only got room for a single panel, get a decent panel and decent MPPT controller to maximize output.
    Personally, I prefer semi-flexible, as they are so much easier and thus cheaper to fit and don't look so ugly, unaerodynamic and nickable as they don't stick out from the roof.
    • Funny Funny x 1
  11. geo glasgow
    geo glasgow Read Only Funster
    Feb 2, 2014
    292
    273
    Glasgow
    there are various amounts of offers
    many members have many types depending what you require and budget.
    i bought the wrong solar chargers twice, first was a 10 amp cheap second was a 20 amp cheap now i have a 30 amp ..
    and two 150w panels. thats my choice it wasnt that much more in money,
    here is a budget system from the guys i bought from first class service.
    the reason i selected this as an example is that you get the plastic fixing brackets for the ends and side very important also dont drill onto roof you will need a flexible bonding agent as shown
    http://www.ebay.co.uk/itm/Biard-100...143299?pt=UK_Gadgets&var=&hash=item58a548f243
    you need this for fixing to roof incl round the cable entry box.
    http://www.ebay.co.uk/itm/Sika-Sika...nding-Solar-Panel-Bathroom/200974928813?rt=nc
    batteries if required,
    single battery, http://www.ebay.co.uk/itm/12V-110AH...ervan_Caravan_Accessories&hash=item27cfc7649a
    pair of batteries .
    http://www.ebay.co.uk/itm/DEAL-PAIR...ervan_Caravan_Accessories&hash=item1c1c5bef69
    you will need battery clamps and heavy duty battery cable from a good car component shop ,, i got mine from maplins not a bad price, make sure battery dimensions can fit under your van or in one of the outside compartments not with the gas and not inside anywhere as they can expel gasses ,,, also secure with the correct means and battery trays with sides or similar. i running cable under van is the only option then cable seal and cable tie often to stop cable wear this can cause arking and be dangerous ,,,
    a good dry day is a must to cure the sika flex fixing compound,
    i have this set up which i just completed a few days back works well and
    i also just fitted a inverter as shown not always required ,,,
    2x http://www.ebay.co.uk/itm/281248073912?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    received 48hrs good product,
    http://www.ebay.co.uk/itm/181311407653?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    http://www.ebay.co.uk/itm/171235058700?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    http://www.ebay.co.uk/itm/171234030110?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    http://www.ebay.co.uk/itm/331113064973?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    http://www.ebay.co.uk/itm/Solar-PV-...005&prg=9264&rk=4&rkt=6&sd=320935573579&rt=nc
    http://www.ebay.co.uk/itm/350847987705?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    http://www.ebay.co.uk/itm/111273008022?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    good luck and there was a few guys on here gave me help when i needed it ,, also dont connect solar panels till all wiring is completed,
    any issues with wiring info just ask on here im sure you will be assisted,
    good luck,,,:thumb:
  12. geo glasgow
    Feb 2, 2014
    292
    273
    Glasgow
    totaly agree check dimentions of any panel
    totally agree check dimensions of any panel your interested in buying
    as you may have several roof windows or a rach or box even a satellite or aerial all get in the way..
    like the idea of the flexible panels never seen them but have noticed them on ebay,
    :thumb:
  13. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,261
    1,353
    norfolk
    We spent a month in Alaska last June, the locals said it was unseasonably hot, we said we had brought the weather over with especially !.
  14. Tmesis
    Mar 28, 2013
    29
    10
    Surrey
    But I said at most and am not concerned with fractions of amperes.
