Which setting to choose on LRM 1218 regulator
Discussion in 'Solar Power' started by Tony M, Jun 17, 2016.
  1. Tony M
    Tony M Read Only Funster
    Jan 25, 2016
    16
    11
    Barnstaple
    I'm in the process of installing a 120 watt solar panel to my Globecar which has a Schaudt EBL 119 Elektroblok (basically a 99 with an AGM setting for the charger) and a Varta Professional LA95 dual purpose AGM leisure battery.
    I've splashed out on a Schaudt LRM 1218 MPP solar regulator which has three possible settings depending on battery type and I was wondering if anyone could suggest which would be the correct one.
    The first is for lead acid so obviously it's not that but these are the two I have to choose from:
    AGM 1 / Lead-gel.
    Charging voltage: 14.4 volts. Charge retention voltage: 13.8 volts. Time phase: 12 hours.
    AGM2
    Charging voltage: 14.7volts. Charge retention voltage 13.7 volts. Time phase: 4 hours.
    I emailed Udo Lang at Schaudt but he just suggested I contact Varta which I have done, but not had a reply. Anyone got any ideas which is best?
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    I would contact Varta technical for complete certainty, but their guide to leisure batteries states the following for AGM:
    • Absorption phase 14.8V
    • Float (retention) 13.8V
    Nothing about the time required for charging but it does suggest a charging current of 25-35% of the nominal Ah capacity of the leisure battery bank.
  3. Tony M
    Jan 25, 2016
    16
    11
    Barnstaple
    JeanLuc, thanks for that. The absorption phase would suggest I choose the AGM 2 setting but the float would suggest AGM 1. Which is best I wonder?
    Still hoping for a reply from Varta.
  4. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    I telephoned them and got answers to my questions straight away.
    Johnson Controls Batteries Limited
    Suite 5, Building 6, Croxley Green Business Park, Hatters Lane
    WD18 8YR
    Watford
    United Kingdom
    Tel: +44 (0) 1895 515650
    Fax: +44 (0) 1923 630899
    E-mail: info-uk@varta-automotive.com
    Website: http://www.varta-automotive.com
  5. Tony M
    Jan 25, 2016
    16
    11
    Barnstaple
    Got the answer from Varta - AGM 2 setting.
    Thanks again JeanLuc
    • Like it Like it x 1
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,643
    3,477
    Telford, Shropshire
    I would opt for AGM2.
    D.
  7. Tony M
    Jan 25, 2016
    16
    11
    Barnstaple
    Many thanks Dave. That's the setting I'm going to go with.
