Which MOT test (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
I have just uprated our MH from 3500kg to 3850kg and should receive back the V5 in the next few weeks.
In the mean time i am going online to the DVLA ( Northern Ireland ) website to book the MOT ( which is due at the start of June ) when it dawned on me which test do i choose now with the new weight ? ( surely its still light goods ? and not the same test as a lorry ) , here are the options listed :
Private Car
Light Goods (Gross weight less than or equal to 3500kg)
Motorcycle (Up to and including 200cc)
Motorcycle (Over 200cc)
Tricycle
Heavy Goods (Gross weight over 3500kg)
Trailer
Bus
From the website : https://www.dvtaonlineni.gov.uk/public/bookVehicleAppointment_1CollectInfo.aspx
tonka
10,829
21,525
Cannock, Staffs
A class Burstner 800
Since 2000
SAME AS BEFORE... MOT on motorcaravans is same as car.. Class 4..
HOWEVER... Best to check they have the space (height) and weight capacity... Some private one's dont, not sure on the place you are thinking of using.
Feb 24, 2013
13,075
101,438
Bolsover, Derbyshire
Hymer S800
not long enough
our MH is called a PHGV on the V5
not sure if that is because it is above 3.5T, it was manufactured as that not uprated
but MOT as Tonka says, unchanged :)(y)
Jim
Ringleader
Jul 19, 2007
36,398
130,735
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Yes I had an 11 ton RV it only required a Class IV but it needs to go to an MOT test centre that can take coaches and trucks.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Thanks all , glad to hear its a normal test.. phew !!!! :)
Re the test place being able to accommodate the large motorhome , that is not a problem as here in Northern Ireland you can only MOT your vehicle at dedicated DVLA test centers.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
many motor homes do tec have the wrong mot . if carrying bikes /m,bikes or boats etc in a garage or load are they are really no longer m,homes but living vans .
luckily vosa as was dont care about it .
the irish vosa used to say two bicycles in the garage and it wasnt a motor home .
