Which LED Bulbs
Discussion in 'Tech/Mech General' started by Dereckerick, Feb 29, 2012.
  1. Dereckerick
    Dereckerick
    Jul 14, 2009
    237
    147
    Merseyside
    Having got the solar panels and digi monitor, im constantly watching my power consumption, especially at night when the lights go on and Im watching telly.
    I have a 2001 Cheyenne, mostly use the spots in the rear at night (now that sounds odd:Eeek:), you know what I mean....
    Can I just whip the bulbs out and put LED bulbs in? What types do i use?
    I know narthink..
    Cheers all
  2. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,096
    Leicestershire
    The standard appears to be G4 LED.. Try E-bay
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    if your spotlight bulbs are side mounted in the lamp you could use these...
    [​IMG]
    if the bulb hangs down in the lamp then these will do....
    [​IMG]
    i got all mine from
    LED BULBS 4 U
    they both come in 6 or 9 led units and bright or soft options
  4. Cyclewalkbob
    Cyclewalkbob Funster
    Oct 12, 2011
    338
    289
    West Sussex
    Depends what type of lights you have.
    If you have spots then they could be MR11's. these led bulbs for these can be seen at -
    http://www.caravanledlighting.co.uk/mr11-6-led-warm-white-bulb-8-30v-18w-73-p.asp
    for down lighters it probably be G4's - something like this
    http://www.caravanledlighting.co.uk/g4-10-led-warm-white-circular-10-30v-2w-4-p.asp
    Look around for best prices at Alten Lighting, Leisure power, CaravanLED lighting and Ebay and Amazon.
    Look and compare watage, lumens, life hours for each bulb
    Best to ensure that the lights have "an input voltage range which s 10-30V DC allowing voltage fluctuations to occur such as a water pump switching on and off."
    As if it does not have protection circuitry then the bulb could fail.
    However bulbs which have it are over £6, without it around £2 so you could get three bulbs for price of one. you takes your choice.
    I after much soul searching, went for the bulbs from CaravanLED lighting.
    hope this helps
    bob
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    In addition to G4 and MR11 you could need bayonet cap bulbs for certain spotlights.
    Aten Lighting do a full range of well made bulbs. See my post (#9) Here as regards quality differences. I'm still awaiting the two bulbs from the other Hong Kong supplier 19 days after ordering.
    Our Burstner had a couple of round ceiling lights with 16W fluorescents in them (one of which I managed to break when finding out what they were). Rather than mess about converting I bought two of the Silver Sand fittings from Ledbulbs4u.co.uk as Aten don't do fittings in the size I wanted.
  6. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    • Like it Like it x 1
  7. GJH
    Aug 20, 2007
    27,349
    34,949
    You need to be a bit careful with the car bulbs. I bought some of These (£17.88 for four, including P&P) in July 2007 (when LEDs were pretty new) and found that they did not fit the eyeball spotlights in our Elddis as the neck was not long enough to allow the bayonets to engage. It's worth checking before ordering.
  8. freelanderuk
    Sep 24, 2009
    1,022
    541
    cheers Graham , i bought 1 of the type i was interested in to make sure it fitted ,then bought the rest
  9. robnchris
    robnchris Funster
    Jan 11, 2010
    1,376
    1,763
    Chester
    led lights
    Hi, we had a Cheyenne and changed the bulbs in the spotlights and also added these strip lights fixing them under the curtain pelmet, gave an excellent lighting effect when the blinds were closed.
    http://www.ebay.co.uk/itm/250748086100?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    The guy is really helpfull, you can get them different lengths to suit or if you can handle a little soldering buy a 5mtr length and make up you exact requirements.:thumb:
  10. veevee
    veevee Funster
    Jul 4, 2010
    984
    551
    Essex / central France
    Three questions -
    Is it possible to fit LED bulbs in tube lamps? If not do people replace tube lamps with a certain type of LED lamp?
    Is there a set percentage in current reduction used between convetional bulbs and LED's?
    How does the output compare between a tungsten lamp and a LED? I think I am asking if you have a 10W conventional bulb and need the same output in LED, how do you know how many LED's to fit?
    Sorry for so many questions
  11. GJH
    Aug 20, 2007
    27,349
    34,949
    Very wise Chris. Wish I had done the same instead of going for four straight off :BigGrin:
  12. GJH
    Aug 20, 2007
    27,349
    34,949
    Yes, two ways:
    1) Replace the unit as I have just done (mentioned last night).
    2) Buy an appropriate LED bulb (people like Aten and Ledbulbs4u will advise) then remove the tube and clip the wires to remove the ballast from the circuit (remebering to clip on the correct side of the switch) and wire in the LED bulb. I did that on our previous van. It's cheaper and no more difficult than unit replacement but this time I decided new units were preferable.[/QUOTE]
    LEDs use about 10% of the current of conventional bulbs.
    The warm white seem to give about the same amount of light and cool white are brighter. I just replaced one for one on both this van and our previous one. The best way to judge light output is to look at the displays of vendors at shows.
  13. freelanderuk
    Sep 24, 2009
    1,022
    541
    i have also used the same and removed all the autotrail fitted strip lights above the lockers and fitted these led strips , same again using for 2 years with out a problem and no regulator fitted
  14. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,912
    10,285
    :thumb:
  15. veevee
    veevee Funster
    Jul 4, 2010
    984
    551
    Excellent information from all, thank you very much.
  16. Dereckerick
    Dereckerick
    Jul 14, 2009
    237
    147
    Merseyside
    Thanks for all of the great advise guys.
