Which inverter?
Discussion in 'Tech/Mech General' started by seanoo, Jan 18, 2015.
  1. seanoo
    seanoo Funster
    Nov 14, 2009
    362
    217
    normandy
    I have a new satelite reciever and its mains powered so i need to run it through one my inverters. The box is rated at 30 watts. I have a cheap 300 watt inverter and a 600watt sterling pure sine wave inverter , which one would do the job more efficiently? Or should i buy an even smaller one? Cheers sean
  2. hilldweller
    Dec 5, 2008
    27,224
    26,216
    Macclesfield
    Pure sine, always best.
  3. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,107
    5,382
    Guisborough
    Fair chance that the 300 watt will be the best suited, but it depends on he efficiency figures for each.
    Oops sorry, missed the two different types, thought it was just a size thing, I would go with the pure sine as well.
  4. Jonkil
    Jonkil
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Agreed, pure sine wave.
  5. f6c
    f6c Funster
    Nov 7, 2010
    3,246
    867
    gloucestershire
    Same as above(y)
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,943
    17,608
    YO11 2BD
    I would have bought a 12v sat receiver....no need to weigh up the best inverter then.
    • Like Like x 3
  7. seanoo
    seanoo Funster
    Nov 14, 2009
    362
    217
    normandy
    they dont make a quality 12v receiver capable of picking up the bbcs , itv and ch4 down here in almeria. with this box i have all these channels on my oyster .
  8. seanoo
    seanoo Funster
    Nov 14, 2009
    362
    217
    normandy
    thats what i thought , surely the smaller inverter would take a bit less from my batterys to do the same job.
  9. funflair
    Dec 11, 2013
    5,107
    5,382
    Guisborough
    Hi Sean
    If the smaller one is not sine wave it might fry the circuits in your box, or at least not work. what they take out depends on the efficiency.
    I had a non sine wave 2kw and it was B useless it would have taken about 15 minutes do do a 2 minute job in the microwave, I know that is different to a sat box but some things especially with circuits in dont like the non sine wave jobbies, our Nespresso machine just would not work.
  10. seanoo
    seanoo Funster
    Nov 14, 2009
    362
    217
    normandy
    hi martin , i tried it last night on the 300 watt jobbie and it appeared to work fine for a couple of hours , not too hot or anything. just a shame i cant get a 12v sat box to do the job as i like to keep everything 12v in the van.
  11. funflair
    Dec 11, 2013
    5,107
    5,382
    Guisborough
    Hi Sean
    I guess if it works it works, job done.
  12. scotjimland
    Jul 25, 2007
    28,934
    25,602
    not always.. if you are only planning to run resistive or induction loads then a modified sine wave inverter is more efficient, cheaper and less to go wrong ..
    if you need to run more sensitive electronic equipment Pure Sine Wave are recommended.
    For a sat box best to use a pure sine wave.. quasi may work but it can introduce noise and may affect signal quality..
    If unsure or don't understand then buy a Pure Sine wave.. but it's important to size correctly..
    Try not to run a small load on a big inverter, that is inefficient, ideally the load should be about 80% of the inverter full load rating..
    so to run the OPs sat box, which is only 30watt, a 1o0watt pure sine wave would be best ,
    running on a 600watt is inefficient.
    edit.. smallest pure sine wave I can find is 200watt
    • Like Like x 1
  13. hilldweller
    Dec 5, 2008
    27,224
    26,216
    Macclesfield
    Looks like I'm out of date, comes as a surprise to me, not others. From a well reputed manufacturer...
    General opinion over the last few years was that the quasi-sine wave inverter was dead and the pure sine-wave inverter would rule the world (an opinion not shared by Sterling). Sales of quasi-sine wave inverters have continued to out-grow sales of pure sine-wave, proving that there is plenty of life left in this technology. The principle reason is that most of the equipment such as mobile phones, TVs, drill chargers and all that type of equipment which used to have a problem working with quasi-sine wave tends to now work fine on quasi-sine as the effected equipment tends to use a switch mode power supplies in the design which works fine with quasi sine wave. This meant that rather than the problems getting worse over the years the problems have diminished, however, this is not to say that the odd microwave, drill, vacuum cleaner would not work (if there is a thyristor control circuit employed then this can still be an issue) but there is no question this is becoming more rare as the years go past, plus, it usually is a lot cheaper to replace a £35 microwave to a different model which will work rather than spend £700 on a sine wave model to make it work .
    Sterling has invested in a new range of quasi-sine inverters because they are smaller, lower cost, offer better performance, are more efficient and more reliable than sine-wave. We, at Sterling, have always found the quasi-sine wave inverter more than adequate for general requirements in boats and vehicles. There is still the odd appliance, such as washing machines, where quasi-sine wave inverters simply do not work but all in all they do a great job - especially considering their cost.
    • Like Like x 1
