Which gas bottles and connectors do I need? (1 Viewer)
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Morning everyone,
Motorhome has a UK gas cylinder attached. I now need to get & fit 2 French cylinders.
1. Which gas do I get? (Butane? propane? are they different or all the same?)
2. Do I need a different regulator or will a French cylinder fit on the one already there?
I'm sure there'll be more questions along soon-have yet to tackle water systems :winky:
( all drained to avoid frost damage--travelled back on a lot of bottled water!)
scotjimland
2,309
9,979
A Woosh bang
you will need to buy the French regulator and for all season use, better to use propane as butane stops boiling off (gassing) at around +3deg C ..
beachcaster
3,044
3,161
east sussex
a few years
How long are you in france?...........Perhaps the "calor gas" you already have will be enough ?
Not sure of your intended trip........but other people might be able to guess how long 2 calor gas cylinders might last on the continent at different times of the year.
barry
scotjimland
2,309
9,979
A Woosh bang
barry
Hollyberry's Location: Dordogne, France
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Thanks---yes it is a bit confusing that I live in France but bought a UK motorhome.
so I buy 2 propane cylinders plus 1 regulator? And is the regulator easy to fit/ swap over? Should I try to find a garage/dealer to do it for me or should I be able to do it? (I can change cylinders as do this in the house)
Sorry to sound dim--and I haven't even got onto the water yet!!!
stcyr
1,765
1,160
Normandie
On & off, since 1966 - fulltime since 2005
Hi. We got ours from Carrefour. 1 euro deposit and free regulator. :thumb:
scotjimland
2,309
9,979
A Woosh bang
Yes..
It's straight forward job if you have and can handle a screwdriver.
Undue the worm drive clamp and slip it up the hose.. , pull off the old regulator and slip on the new.. if it's a bit tight use a smear of washing liquid on the regulator tail.. replace and re-tighten the clamp.
However.. also look at the gas pipe, they have a finite lifespan so it may be worth while changing at the same time.. should have a date stamp.. if not it probably needs replacing.
If in any doubt, as the retailer to have a look and help change it ..
Scout
3,959
121,136
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
dont forget to put old uk regulator in your spares box, just in case you come over here and need gas (allough you will need a uk bottle so why not bring the old uk calor bottles back next time you come home and leave somewhere over here)
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Wise (I hope advice) !
DON'T take a chance with gas......Get a local gas retailer to do it for you !
He will have all the equipment to check for leaks once fitted ! Stephen.:thumb:
14,732
75,879
UK
Self Build
If you keep the UK regulator, ensure it is kept in a sealed bag to prevent dust/dirt ingress.
Swapping regulators is easily a DIY job. However swapping the entire hose may not be depending on how competent you are and what type and location the other end of the hose is. On one of my vans it was recessed back and very hard to get to, it was hard to tell if I had tightened the jubilee clip enough.
If it is just a regulator swap then this is a DIY job in my opinion. I use a spanner not a screwdriver on the jubilee clip however as I find it easier and less chance of slipping and gouging a chunk out of the palm of your hand :Doh:
scotjimland
2,309
9,979
A Woosh bang
better still, and a very useful tool is a 7mm flexible shaft nut spinner .. a must for every motorhomer.. will get into the most awkward of places with ease and no gouged hand..
but I didn't think Holly would have one ..
Broken Link Removed
