which filler which sealer (1 Viewer)
craig.drake
45
queensbury
coachbuilt
since may 2010
having found the sorce of the leak under the back bumper a little rotten wood needs filling and then will need to reaseal the underbody .just not sure which to use any advice on products would be appreciated
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
In a perfect world the rotten timber would be replaced, however if filling is the desired method I would recomnd googling for a local supplier of structural resin, available as a two part resin, will set stronger than the wood and also will set and stick in damp wet conditions, dig out as much soft wood as possible you might want to look at splicing in some new timber where possible using the resin as an adhesive,
then seal bodywork as normal with sikaflex sealer
Geo
