which engine for hymer (1 Viewer)
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
can anyone tell me if the fiat 2.8 engine is a significant improvement over the earlier 2.5 version when fitted in the hymers ? it seems to give out an extra 10 bhp [i think] or does the more complex nature of [what i presume will be a common rail electronically fuelled engine] bring more negatives than positives ?
JJ
Mágica
May 1, 2008
19,258
48,031
Burstner Privilege T
over 50 years
I have not driven a 2.5 engine but my Iveco, with its 2.8 turbo is a joy to drive and pretty quick should you choose to be in a hurry...
I feel that engine cc is like computer RAM or beers in the fridge... the more you can have the better it is... :winky:
JJ :Cool:
chatter
3,689
937
cheshire
5th wheel
errr question for you do both engines use the same gearbox and change ratios or would you also have to change the gearbox and not knowing much about engines would the diff also be compatible
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Either the iveco or merc engine are he ones to go for, avoid fiat!
This is what all those in the know advised us when looking at hymers and laikas
rainbow chasers
3,680
1,725
Mid Cornwall
Various
The Fiat 2.8 JTD is an Iveco engine.
lol! Fiat have their paws in everything these days
new one is, old one was a ford....which explains why the newer ivecos are troublesome. Very unrefined engine though, the ford one, but is reliable if leaky and stinky as they are.I would stick to a merc over iveco, but that was what we were advised.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
the earlier iveco daily vans had fiat engines then went to ford engines but now the fiats are on iveco engines but seeing as fiat own iveco vans and ford own iveco trucks.
i even believe that some of the small ford duratorq engines are a fiat one.
as for the mercedes engines they were great up until the advent of the CDi since then they have lost their reliability
con-tiki
457
187
Leeds, West Yorkshire
A class Hymer
since 2009
My sis had a 1995 Hymer fiat 2.5td, then drove my 2000 hymer 2.8 fiat....she said the 2.8 had a lot more 'poke', so much so she changed hers for a 2002 hymer 2002.
Shirl
Johnnie Gee
59
19
Near Aberdeen
Since 2000
Fiat 2.5 & 2.8
I started with a 1997 hymer 564 which I thought was fine for the size of the vehicle, my next van was a 584 with the non common rail 2.8 and went really well, a marked improvement on the 2.5.
I then bought a 624 with the common rail 2.8 and it was a bit of a slug compared to the 584.
The base vehicle was a bit heavier, but it wasn't as nice to drive!:Sad:
I fitted a tuning kit box on to it and it is back to the same standard as the 584 now.:thumb::thumb:
As mentioned before you don't expect racing car performance but it is nice to have a bit of go under the pedal!:Smile::Smile:
Only down side is, it's a bit harder on the clutch, so go steady with the left foot if you do go down that route:RollEyes::RollEyes:
Good luck
JJG
43,324
49,440
it doesn't matter what its fitted in, the 2.8 is superior to the 2.5.
I've had both, in Kontiki's, and the difference is very noticeable.
the 2.5 was in a 3500kg van and the 2.8 was in a 3850kg.
even though the 2.8 was 350kg heavier it was far better to drive, having the extra 'umph' when needed.
