Which 1.9d vw engine needed?
Discussion in 'Tech/Mech General' started by Breconeer, Jul 24, 2012.
  1. Breconeer
    Breconeer Read Only Funster
    Mar 9, 2012
    9
    Herefordshire
    Which vw 1.9d watercooled engine will fit our 1982 T25 van? And where best to look for one? We are urgently looking to replace the 1.6 watercooled diesel engine which finally died in a noisy smokey way last week and is beyond repair. Van is in fairly frequent use (except right now of course with engine out), and was due to be on a campsite for the next 6 weeks with assorted grandchildren. Engine needs to be one with compatible mountings and connections, rather than one needing chassis alteration.
    We have a guy lined up to fit a replacement but need to find one. Clues we have from him - none of which mean anything at all to me as a non-mechanic, so apologies if I'm writing them wrongly :Eeek:
    are that it needs to be a non-ECU engine. AEF,1Y,!X,or KY(1700). Cold run spark lever (cable). One live feed wire for stop solenoid. No wires going to injection. Indirect injection.
    Oh and please do tell me which forum section I should be posting this in if this is the wrong one.
    We are at Bromyard, Herefordshire.
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,236
    16,842
    Liverpool.
    What you describe sounds very much like a MK3 golf none turbo from around the early 90s. Something like a bog standard CL or rabbit.
    If so its also a good contender for the use of biofuel.
  3. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    might be better to look for the skoda lump.
    best to get a non fly by wire set up .it is possible to use the fly by wire but you need part of the speedo cluster as well. you can by a adapter box these days usually from a german crowd . but i would pick up a skoda lump and change flywheel and clutch etc .
    the other way isuse an adaptor and put the 5cyl audi lump in . this is all possible .i used to sell a 4cyl adaptor to put golf passat petrol engines into the wasserboxer vans . i sold the adaptor to another chap down here . he then went on to do the 5cyl and the fly by wires . if you need help pm me i can give you his number. i think or can get it i,m sure .
  4. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    the best way to find out what you need is check out the vw forums there will be hundreds will have been down this road in the past.
  5. Breconeer
    Mar 9, 2012
    9
    Herefordshire
    engine found and fitted - but
    Engine found and fitted. Works nicely. Also found and fitted a new fridge. But a hit-and-run truck driver gouged the whole of one side of the van while parked on a street in Cheltenham, tearing both wheel arches, both doors, etc. Fortunately a bystander noted enough of a description for us to go look down the street he turned into, where we found and photographed him and his truck - his truck liberally marked with our white paint marks, and ours liberally marked with his green paint. Despite which he denied it. Still involved with insurers at the moment. :Sad:
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,740
    5,967
    Mansfield,Notts
    Ah the ole truckers best defence
    Never felt a thing Governor Honest:RollEyes:
    I involved the police in a very similar incident, they were very help full in gathering the evidence, even tracked the truck down for me from the times I gave of the damage, they had local knowledge of what lorries ran down what roads on a regular basis from local firms:thumb: and nailed him:Cool:
  7. wilfredes
    wilfredes Read Only Funster
    Oct 12, 2012
    United States
    I'm awesome like that!
    [​IMG]
    [​IMG]
  8. Breconeer
    Mar 9, 2012
    9
    Herefordshire
    Struggling to find a left-side sliding door (rhd van) for a T25 van of this year (1982), so it looks like our local bodybasherman might have to untwist the damaged one and rebuild it :Sad:
