Where to buy?
Discussion in 'The Beginner' started by eclaire, Mar 30, 2010.
  1. eclaire
    eclaire Read Only Funster
    Jul 24, 2009
    24
    Nottinghamshire
    Looking for our first RV (we currently have a big caravan) and wanting - we think- a Winnebago either brave or vectra. Apart from Ebay and general internet search can anyone point us in the right direction? Budget of about £16K so probably 95ish? needs to have a sofa and island bed layout and be ok on a car licence.
    The idea is to buy it, try it out for a few weekends then sell the caravan if we like it, or it if we dont like it!!
    thanks
    claire:-}
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    There are a couple on ebay at present, don't know them but something to look at maybe?
  3. davejen
    davejen Funster
    Aug 21, 2008
    1,262
    718
    Kirkpatrick Fleming Dumfries
    Hi, Claire, I think the Vecta is over 7.5 tons so not car licence, unless it's a Vauxhall Vectra!, and I wouldn't go for one of them!
    Cheers, Dave:thumb::Rofl1::Rofl1:
  4. gar163y
    gar163y Read Only Funster
    Dec 23, 2008
    9
    Uckfield, Sussex
  5. motorvating
    motorvating Read Only Funster
    Feb 28, 2010
    121
    28
    Hinckley
    Check this site out.
    http://www.motorhomes.mobi/Motorhomes/tabid/95/Style/American%20RV/Default.aspx
    I think I saw a post on another site from you about a none runner RV.
    Buying a RV is an expensive business, and if rushed will cost you a shed load of money in repairs.
    You need to check everything works correctly by gas mains and 110 volt, if it does not deduct the cost of reparing it from the price, unless of course the seller has already done that.
    Check the tyres because you will pay anything upwards of £500 for new tyres. If they are 7 years old they need replacing. If they are cracked on the wall they need replcaing and of course if they are worn.
    Check for corrosion everywhere, and get under the RV to check. Really check closely the side lockers as they are mega expensive if corroded. Open the lockers and check the metle frames.
    Check the floor of the RV for spongyness, if it is spongy investigate the floor.
    Check for water staines inside in every cupboard.
    Check toilet holds water. A blade closes and has a few inches of water sit above it to keep smells at bay.
    Fill the water tanks and watch them drain to check the plumbing.
    after you have checked go away and think about the problems before deciding to buy.
  6. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,285
    16,955
    Liverpool.
    Hi,firstly if you are concidering buying an RV its going to cost you quite a lot of money whether you buy old or new.
    The maintenance on these things can be astranomical if you dont know what you are doing.
    Even if you do know what your doing they are not cheap to run.
    What may seem cheap to start with can quickly turn into a bottomless money pit.
    Everything on RVs is bigger so it costs bigger,for example I just put new front brake pads on mine,£150. Fitted myself.
    Tyres,a minimum of 3 times the cost of European tyres.
    The list goes on and on.
    That said,we would never part with ours,the comfort you get from them cannot be compaired with anything else only a yank.
    Good luck with your search and remember this.....Do not believe ANYTHING an American RV dealer tells you.
  7. eclaire
    Jul 24, 2009
    24
    Nottinghamshire
    Thanks Dave, the baby vectra comes in at just under the 7.5 at 16,000lbs but anything bigger is a no go!
    One on ebay looked ok till we HPI'd it and it said it was cat B!
