where is the fuse
Discussion in 'Motorhome Chat' started by bernardfeay, May 3, 2011.
  1. bernardfeay
    bernardfeay Funster
    Nov 18, 2009
    585
    837
    Bolton
    I have a Hymer Exsis sitting on a Fiat Ducato 2004. It is the 2.3 diesel jobby. I have 2 cigar lighters at the front and they have both blown fuses. I found the one for the actual cigar lighter and replaced it. That now works fine. But the other is called "current connector". To all intents and purposes it it just another cigarette lighter.
    The diagram in the manual identifies it on the dashboard but it does not appear on the fuse list. I know it is 15 amp and I have looked at all my 15 amp fuses; they are all ok now that I have replaced the first blown one.
    It is just possible that a previous owner replaced a 15 amp with something else and for that reason I can't spot it. If anybody knows where it is I would be so grateful.
    Thanks Bernard
  2. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,497
    895
    South Glos
    On the 2.8 it is fuse 65 on the fuse panel on the right hand side fuse panel (drivers side for RH drive vehicle)
    If you have the ducato owners manual it is shown in fig 38 on page 151 and in the allocation list on page 154
    Hope this helps
    Lunarman
  3. bernardfeay
    bernardfeay Funster
    Nov 18, 2009
    585
    837
    Bolton
    Thanks Lunarman, I'll check it first thing in the morning.
  4. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    You may also like to check the fuses that are built onto the positive connection on the battery, but check the alternatives first as it a bugger of a job getting at the fuses, you have to remove the battery and the fuses are bolt on types.
    Doug...
  5. bernardfeay
    bernardfeay Funster
    Nov 18, 2009
    585
    837
    Bolton
    I have had to replace one of those fuses on the battery terminal before and I do carry spares. I'm hoping I'll find it where lunarman suggested
  6. bernardfeay
    bernardfeay Funster
    Nov 18, 2009
    585
    837
    Bolton
    I followed your advice lunerman and I did find the fuse. It was all nice and shiny with no break. The socket still doesn't work so my problem must be something other than a blown fuse.
  7. artona
    artona
    Jul 31, 2007
    1,480
    690
    How do you know it is not working? Have you tested it with a meter?
    stew
