Where is my battery
Discussion in 'Tech/Mech General' started by Tango, Dec 26, 2011.
  1. Tango
    Tango Read Only Funster
    Dec 26, 2011
    5
    7
    Preston
    :helpsos:
    Any help or advice would be appreciated
    I have a 2009 Lunar Roadstar fiat ducato 3.0 multijet
    the cab battery goes flat over winter and i have used the car to start it occasionally
    I would like to give it a proper charge, but cant find it :Blush:
    I dont think the cab battery charges on hook up
    I could connect a battery charger to the terminals under the bonnet, but dont know if i need to take the caps off that cover the distilled water/ acid and lead plates, in to release pressure that builds up if sealed
    help and advice will be gratefully received
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,628
    11,916
    Champagnac-La-Riviere
    Mine is under the floor passenger side biggish panel to remove then another under it. :thumb:
  3. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    Try the panel in the passenger side floor. The plastic panel lifts out revealing the battery & some large fuse blocks:Smile:
  4. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    use the battery jumping point under the bonnet to charge it the floor lifts in the front footwell to reveal the battery
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    for normal charging you shouldn't need to remove the caps, if it has any.
    it will either be self venting or have a vent tube.
    a standard car charger (4amps-ish) will work fine over a day or two.
  6. Tango
    Dec 26, 2011
    5
    7
    Preston
    thanks for the quick replies
    two more questions if thats ok
    1 I did remove a plastic / rubber panel in the floor on the passenger side, which revealed a metal plate with 13mm bolts holding a metal plate / cover in place. Is the battery under that?
    using the battery jumping point is no problem but I am concerned that I havent then removed the cell caps like I used to have to do on my mini 30 years ago when charging it :Blush: are all modern btteries sealed now or are you still suposed to remove the covers when charging?
  7. pappajohn
    Aug 26, 2007
    30,258
    17,927
    YO11 2BD
    see above :thumb:
    but if you want to rapid charge it (20/30amps) it may be worth removing them as the levels may need topping up.
  8. jhorsf
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    If you have a handbook look in page 202/203, I have it on pdf, if you want it send your email by PM and I will try to send it you, the panel you want in the floor is in the centre front and has no metal plate at least mine does not just plastic turn buckles
  9. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,494
    894
    South Glos
    On my 2006 roadstar the cab battery will charge on hook up only when battery is selected on the control panel.
    Lunarman
  10. Tango
    Dec 26, 2011
    5
    7
    Preston
    thanks Lunarman, the display is all digital, so not sure its as straight forward as that, but will giveit a go :)
  11. dellwood33
    Apr 25, 2009
    3,449
    887
    Newcastle
    Loosen the 2 13mm bolts & the metal plate will hinge forward to reveal the battery, or you can slide it out if you need greater access.:Smile:
  12. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I have the 3 ltr fiat .and my battery lives centrally in front of the driver and passenger seats in the floor. Large panel comes off to reveal battery.
    Mine is almost certainly a goner...........I took it out ( heavy swine) and took it to a local battery specialist and he is trying to revive it ...but the readings were very low.
    Looks like I may have to buy a new one next week.
    I am now thinking of buying and fitting a battery managment system that will top up the vehicle battery automatically like the battery management unit from VanBitz
    barry
