where is it?
Discussion in 'The Beginner' started by pamella, Sep 4, 2013.
  1. pamella
    pamella Read Only Funster
    Aug 19, 2013
    146
    39
    walsall, west mids
    where could our drain down valve be for the truma water heater?
    its the old black one ...1988 on the sticker.
    would it not have had one then??:Blush:
  2. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    almost 50 views and noone has a clue?it cannot just be me then~?
  3. Peter & Elaine
    Peter & Elaine Funster
    Aug 30, 2012
    4,019
    6,543
    Roobarb land
    Can say with yours but ours is at side of boiler pull up a small Black plunger and lift a small red lever then all water runs out
    I tried :thumb:
  4. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    oooh thats sounds interesting.ive been looking for a yellow lever.i will have another look after school run.thankyou.
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    There are Installation and Operating instructions for a range of Truma boilers HERE and HERE which might help.
  6. rangitira
    rangitira Funster
    Jun 30, 2010
    6,443
    13,423
    Cornwall
    The one we had in our G Reg (1989) had a brass nut on the bottom, that drained the whole thing, but you had to place a bowl under it as it drained straight on to the kitchen unit, and not outside:Doh:
  7. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    where in your van was it?
  8. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    thanks.i have these but still cannot find it.will it only be right near the boiler?it cant be any where else can it?
  9. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    right,so in the bottom of the wardrobe i can see the fresh water inlet and can follow that to the tank under the seat.then from there i can see the clear white tube that comes from where i think the pump would be drawing it up and can follow that tube all the way to the boiler.there is nothing attatched to it apart from the two jubilee clips holding it together where it has either been cut or maybe something used to be there(nearer to the tank than the boiler).
    over on the opposite side under a seat is a red drin down valve,i opened it and alot of water drained from it?what could that be?it seemed alot of water to just be sat in pipe work.this pipe is also clear white.
    underneath the van about 3 foot in behind the wheel on the same side as the boiler i can see a white tube sticking out of the floor?the type you would put a grey tube on to empty grey water?
  10. GJH
    Aug 20, 2007
    27,349
    34,968
    The drain should be near the boiler.
    Perhaps if you could take and post some photos of the boiler somebody may be able to identify where it is.
  11. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    yeh,i've followed to tube with my hand that takes the pumped water from the tank to the boiler and found nothing.i am wondering if it has been directed around the van to the other side and that is what i emptied earlier..it is this one..
    Boiler 50 mbarSeries 1,
    from year of manufacture 1986
    until year of manufacture 02/1992
    on the truma site,one of the earlier posters put the site on
  12. GJH
    Aug 20, 2007
    27,349
    34,968
    OK. See diagram BO on page 3 of the PDF. The yellow lever which you mentioned earlier is the part labelled 14.
  13. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    yep,i can see 14 on the diagram but it is definately not there.the hose does split off to go to the toilet and round to the kitchen.just before the kitchen there is a valve there?
  14. GJH
    Aug 20, 2007
    27,349
    34,968
    It should be somewhere near the boiler as, otherwise, it won't drain it. To progress any further I really think photos of your particular van are needed I'm afraid.
  15. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    okey dokey will get some on here.thanks
  16. pamella
    Aug 19, 2013
    146
    39
    walsall, west mids
    sorry i didnt come back with the photos but we went away over the weekend.
    i have got an english manual and discovered that our drain valve is indeed opposite the boiler and fresh tank and the white spout underneath is the drain down for the fresh tank.
    so by opening these up i think we can drain down properly?
    what is the thing where you blow down the taps please?
    once i have mastered this do you think the mh is ready to be laid up for winter?obviously empty the waste too.??
  17. GJH
    Aug 20, 2007
    27,349
    34,968
    As far as I'm concerned just the shower hose. Remove the head and blow down the hose. I believe that some others use some sort of kit to make sure everything is totally drained. Hopefully somebody will come along to explain.
